steering column
Been thinking of replacing the original steering column to a modern collapsable aftermarket one. Which brand has the best column for a -66GTO?
Reef turqoise -66 GTO Firebird Convertible -68 R.I.P. -73 LeMans 350/350 Barnfind Last edited by A.J.; 02-01-2013 at 04:09 PM. |
Bumping this one as I still havent made up my mind. Which is best, flaming river or Ididit for my 66 GTO?
Reef turqoise -66 GTO Firebird Convertible -68 R.I.P. -73 LeMans 350/350 Barnfind |
Neither, the aftermarket early style tilts are nothing special, developed off common van tilt mechanism. If you're worried about crash survivability, a more modern collapsible design column, you could swap out to a '67 or '68 FS tilt column, but you will have to change out the '66's dash bezel to a '67, as the arch cutout on the '67 bezel for the lower bowl area of the '67 column is larger diameter. The '67 & 68 style column provided both collapsibility in the outer mesh tube & in the steel shaft. The outer mesh tube design was continued on into the 80's by a few OEMs.
Not that keen on replacing the dash bezel and not that keen on driving around with a spear pointing to the chest. I guess that you mean that those aftermarket columns are pricey not adding anything special? Any other options?
