Hey guys I wanted to just ask and see what is availiable to us Pontiac guys? I would simply like something exciting under the hood. I would like to try something beside an old tired overpriced tri-power set up. Is there anything else out there? I have a fairly simple 455, 96 heads, RA4 cam...yada yada...
Whats out there for us to use? |
Hard to beat a factory Q-jet intake with a properly adjusted/modified Q-jet on top?
Will be more than adequate for your engine. |
http://www.kinsler.com/page--GM--17.html
This looks very cool and is probably very expensive! Kinsler would probably work with you to set one up with EFI contols and the whole enchilada, but it won't be cheap! |
what's exciting under the hood of my car is a stock looking cast intake and Q-jet, and the car runs low 12's ;o)
color me gone |
I prefer "priceless" vs "exciting".
Priceless is the look you get in staging lanes when folks watch you make a run deep into the 11's, then wonder over and see the stock intake, q-jet, and stock Shaker set-up under the hood!.......Cliff
I already have a factory q-jet. Although I wish I would have refinished it more nicely when I rebuilt it. But its on an RPM intake.
And that Kinsler is nice, but I really dont want to spend more on the injection than I did on the car. I was looking at the Holley EFI last night, $3100 +........no damn way.\ Edelbrock dual quads could be a possibility.... Or maybe I should just get some nice sheet metal or billet valve covers and a better looking air filter for what i have. And I have kind of a janky throttle/kickdown bracket set up. In fact I had to bend it way over to fit the lower Q-jet on there from the Holley it replaced. Maybe even some nice billet pulleys or something. |
hey Port Orange.....I use to live there 1979-1989
![]() ![]() I have the billet pullys also,nice looking and the grooves are deeper,no belt jump.
color me gone |
If you want something that looks nice, Demon carbs are good lookers, Professional Products Projection III is neat and tidy, Edelbrock with dual carbs is neat, but like Cliff says, a Q-Jet that kicks ass is just "Priceless".
Maybe once I get this q-jet dialed in a bit better and some more converter!! Took the car out last night and it was the best it has run in a looong time. Not quite there yet though!
![]() Quote:
And my car will possibly never see the track again. SO its more for show than go. The Projection system looks interesting. And is a bit more affordable than the Holley set up. |
![]() Quote:
![]() I will not run in the low twelves, it's pure highway cruiser with 2.78:1 gears, but I would bet it will push them back into the seat...... That excites me! Karl ![]() |
I feel ya Karl!! Problem is that is how I have had it for around 9 years. Also about 450 hp...but mine sounds like 450 hp! I do have tall chrome valve covers, and a chrome round air filter. Other than that, shes pretty well stock (the Edelbrock intake is painted the correct Ponco blue. Also have an HEI. But its a pretty much stock look. Maybe I should start by restoring the alternator and stuff back to new looking before I start getting crazy. Mine is extra boring because there are no power brakes, no shroud, no A/C....just a big empty boring engine bay. But since I got the new HEI, they sent me one with a red cap (yuck) and when I got new wires for it all they had in good ones were blue (also yuck). so maybe I will sort this stuff out before doing much else.
By the way the chrome air filter and valve covers recently were painted semi-gloss black because they were starting to rust from being super close to the ocean. Maybe i will sneak out and grab a pic tomorrow. |
![]() Quote:
Merry Chirstmas!
For exciting looks, the options are end less... however I do like the "stock as a stove" look while able to rocket passed what ever comes your way. But on the other hand your personal touch to your Pontiac is also a cool addition. Since you mentioned fuel injection, MSD is also another vendor you may want to look into. Their EFI is still pretty new so I would give them a bit to work out the bugs.They have a cool video on the their web site of the Atomic EFI install. |
![]() Quote:
![]() Go ahead and buy a Demon carb off Ebay, one that someone has lost their mind over, trying to tune, and now wants to sell it cheap...gitterdone ![]()
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
Thats pretty much where I was at before the RPM and Q-jet! Cep it was a gas stained T-1 and a Holley....then a Demon (someone gave it to me). The Demon leaked like crazy as soon as i touched the key. So it came back out, holley went back on, and I started the q-jet rebuild.
Here's where she's at right now.
Couple more. One thing that has always bothered me is the radiator hoses. But I never have any idea which one I could put on since I don't even know where the radiator came from. Probably going to get one of those nice billet adjustable water necks. Not sure about the bottom hose yet.
![]() Quote:
The first thing I noticed was the God awful radiator hose! Also agree that a major detail would go along way before throwing money at carb and intake, kind of like putting lipstick on a pig. Any way thats how I see it as it sounds like your more conserned with the look rather then the function, I assume your happy with the engine and tune?
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Eye candy that you won't often see under the hood of a Pontiac.
Sold it all to a '62 421 SD owner to go with an old tired overpriced Tri-Power setup for my '64 421 HO. ![]() ![]() ![]() ![]() |
