THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
amp gauge vs voltage gauge
whats the difference and which one is best to use in your old car?
Amp gauge requires you to run the main current supply through the gauge....I don't know any auto electrician who recommends still using them. Volt gauges are more useful anyway, lets you know the system voltage rather than just the current draw at the moment.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
Think of it in relation to water... Volts would be the water pressure in a pipe... Amps would be how much water is flowing in the pipe.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt. |
An amp gauge actually uses a shunt... a type of very accurate resistor. A certain current through the shunt creates a certain voltage across the shunt, which is shown on the guage. With a shunt, the full current doesn't have to flow through the guage.
I'd figure on a Volt meter so I can see 14.4V vs 13.8 & less, to indicate alternator health.
Not always easy to know the alternator is working without that. |
Use both-- best of both worlds
Simply put, a voltmeter can be hooked up anywhere in the system, across the battery. You can hook the positive to any switched/fused connection and the negative to any good ground point. An ammeter needs to be hooked in series with the battery flow so it requires all the current to flow through it. Hooking a voltmeter up that way will fry it because it has no shunt across the meter movement.
A voltmeter can give a good indication of potential problems by watching the meter when starting, if it falls below about 10-volts, that's an indication you may have problems developing. It also shows charging system problems as they develop. Battery voltage will drop even though an ammeter might indicate that everything's okay.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
As stated above, not all Amp Meters need to have the current flow through the actual amp gauge, some styles have a remote mounted Shunt and only smaller gauge wires are required to run to the actual amp gauge.
here is an example....http://www.cruzpro.co.nz/a60.html I would just keep it simple and use the volt gauge.
1970 Lemans Sport, PPR 383/4spd. |
The traditional aftermarket ammeter requires that the main cuurent path be routed thru the firewall, thru the gauge, and back underhood.
The large body Pontiacs had a shunt as part of the underhood harness which required only two smaller gauge wires to be run to the internal gauge. A voltmeter is preferable to use as part of a gauge package, but being who I am, having both would be cool, but I wouldn't use the traditional aftermarket style. George
Having the
They are easy to hook up and are a great diognostic tool ( as is a fuel pressure gauge). I have both on my '66 GTO and highly suggest everyone doing the same.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
