Old 10-25-2012, 11:10 PM
TSMartin TSMartin is offline
Default 1962 Dash Pads
Question: Did all full size cars come with a padded dash pad or did some of the lower priced models come with some kind of metal/plastic filler panel or cover between the dash and cowl?
The reason I'm asking is the dash pad on my Bonneville is shot and I don't want to spend the $$$ to have it fixed. I'm building a driver ... not a show car. However ... I don't want to leave a gaping hole around the dash panel.
TS
Old 10-26-2012, 09:33 PM
stucky2947's Avatar
stucky2947 stucky2947 is offline
I don't for sure about the other big cars, but the GP dash pad goes to the windshield while the Cat one is a partial. I believe the Bonneville is a partial also. The area between where the dash pad ends and the windshield is metal.
Mike Stuck - "Stucky"
1962 Grand Prix, 408 w/tripower, ported / polished #62s, TH400, 3.42 posi
Old 10-26-2012, 09:55 PM
Stuart's Avatar
Stuart Stuart is offline
This is a Catalina dash pad: http://justdashes.blogspot.com/2011/...-dash-pad.html If 1962 cars were like 1961, the top of the dash (on cars so equipped) had a separate pad from this part. I've seen people simply use a 1/8" layer of foam glued to the dash top and then covered with a piece of naugahyde, it's mostly flat so stretching and fitting the naugahyde isn't terribly hard. If you can't find the exact color naugahyde locally SMS in Oregon can provide it.
Old 10-26-2012, 11:28 PM
Bonneville ... at least mine ... also goes all the way to the windshield and is "clamped" by the moulding. I was looking at it closer today and was thinking since the pad is shot I might as well strip it all off and see what is underneath. I doubt I will ever have it recovered because ... like I said ... I'm building a driver.
Thanks for the input.
TS
Old 10-26-2012, 11:30 PM
Yeah ... I saw that too.
TS
Old 02-29-2024, 09:47 PM
Pattyhunny Pattyhunny is offline
Default New member eufaula oklahoma
Hello, we just purchased a 62 bonneville that had been sitting since 1975. Super excited to get it running and ready to be my pretty weather daily driver
