Pontiac - Race The next Level |
View Poll Results: What engine stroke would you build for your next race engine? | |||
3.750" | 8 | 7.41% | |
4.000" | 33 | 30.56% | |
4.250" | 25 | 23.15% | |
4.375" | 12 | 11.11% | |
4.500" | 25 | 23.15% | |
4.750" | 9 | 8.33% | |
Multiple Choice Poll. Voters: 108. You may not vote on this poll |
What size stroke????
What engine stroke would you build for your next race engine in a standard deck aftermarket Pontiac block if you had to choose from one of the following sizes?
3.750” 4.000” 4.250” 4.375” 4.500” 4.750” Thanks. Calvin Hill Hill Performance 708-250-7420 |
4.25 bore x 4.0 stroke 454, since I have another 4" crank.
Already got two 4" stroke std deck 400/433's. But would really like a 4.35 x 3.75, preferably in a short deck, aluminum even better. That reminds me, I need to pick up a powerball ticket today...
https://www.facebook.com/Outlaw-Vint...7899333725868/ |
4.25 or 4.375 not sure yet but one will end up in my motor within a year or so. Maybe, i think. I need a bigger motor for Milan AM
Or maybe just do a little SB2?
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
4.125 is nice size for most heads available. Port volume can be an issue with the bigger engines if you want them to rpm....
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
NSS Motor Comb.
4.35 bore and 4.25 stroke for my new comb. and also to run heads up in Norwalk.
505 KRE HP head 2x4 HP 1000s 60' 1.33, 5.78 @ 120.88MPH in 1/8 9.11@149.8MPH in 1/4 |
thats a nice combo.
I wonder why more guys aren't running 4.75 strokes? If I remember correctly, aren't 632 BBC's a 4.75 stroke and a similar deck height? If it works for them, why wouldn't it work for us assuming you have a head that can feed it.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
That's a good question Hooter. All Chevy guys I talk to that runs that combo, likes it has no issues. They have been running all year and putting on about 200 passes or more. I don't see why the Pontiacs couldn't run it too.
I like 482 CI 4.25x4.25 using stock deck height...seems right for a lot of reasons. Gasket sealing, intake runner length, piston speed, and available heads. I question crank durability not to mention ring life going much beyond 4.25 stroke. If you are going to keep rpm down I guess the 4.375 or 4.5 stroke is ok. (4.25 stroke 6.8 rod 7500 rpm = @8746 Feet per minute max piston speed, 4.375 stroke 6.7 rod 7500 rpm = @ 9040 Feet per minute max piston speed. By contrast the little 3.75 stroke 6.625 rod goes 8500rpm plus for same piston speed as 4.25/6.8 combo at 7500)
I like the 3.75" and 4" strokes with no more than 4.25 bore but think they are better suited for a shorter deck block. The piston/rod are kind of heavy at normal deck height. Shorter deck would favor intake with shorter runners for higher rpm power and lighter recip aids durability. I'm doin a low budget 406 for time being till I can build my better motor the way I really want it. I'd prefer a forged crank in the 406 but confident factory cast will hold up just fine for the level of power it will make with the mostly old school parts I'm gathering.(550ish???) |
My answer would depend on at leasr 3 otrher factors you did not list-
1. n/a? blown? 2. gas? alky? nitro? 3. application Most of the strokes you listed can work nicely depending on other perimeters.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
Ok Steve use mine for example. N/A on alky and a very heavy 3450 bracket car that needs the torque to get up on the back tires to make this car work. I have used a 4.50 stroke in the past and work good but, looking go to the next level.
Just to put it out there. I have 4.375 assemblies IN STOCK. Flat Top Pistons.
http://www.pacificperformanceracing....ankshafts.html Ace
Am I glad I got out of the business I was in? HELL YEAH!!! |
4.50 for obvious reasons.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Cant get enough head You cant ever look at 1 part by its self, it always is affected by another part ,as well as affecting other parts its self.
Because they have heads that flow enough to support the cubic inches.
Bruces numbers are based on max piston speed, I like to look at the mean piston speed and the effects on the stroke / RPM. Shooting for a high mean piston speed, somewhere around 5400ft/min. Using that number, the target of 5400ft/min will require the following RPM's for each stroke listed:
3.750" 8640 RPM 4.000" 8100 RPM 4.250" 7623 RPM 4.375" 7405 RPM 4.500" 7200 RPM 4.750" 6821 RPM Calvin Hill Hill Performance 708-250-7420 |
does rod length become a factor here or is it still just a byproduct of stroke and pin height
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
Well my next combo will still be my 455 if it survives until I'm ready - after that 4.00 stroke in a IAII. I guess I could go larger stroke but then I could go larger heads then need to redo my chassis ... Oh man this is a viscous cycle$$$.
So just trying to keep it relatively cheap. I know myself the more cubes would be all the more reason to go larger head. |
