Does it look like this plug is leaking?
This is the distributor oil plug I think. It is on the back of the engine near a freeze plug.
It could be leaking oil or maybe it just has oil from a leaking rear main or oil pan that got thrown up to the area by the flywheel. Your Thoughts? thanks Ray |
I guess the engine is out or about to have a trans. bolted up, so why not just change it to be safe??? Ad some real good thread sealant to the plug and reinstall it??? Personally i don,t think its leaking would be dripping more than pictured. Just my opinion.
Yes the motor is out to fix a oil leak. I was thinking a rear main or oil pan gasket.
I may fix all 3 just to be safe. |
CYA,,,you are there, better safe than sorry. Pull the plugs, clean up & reinstall with pipe dope sealant.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
I really dought if the rear seal could throw oil up that high or even the pan,
Looks to me like the goo on the plug IS sealer that someone didn't wipe off after screwing the plug in.
Thanks guys.
