New combo first runs ye ha!
Finally got me new combo to the track. 3,700 lb 69 Gto full trim street car drivin' 25 miles one way to/from the track.
Jeff/Shaker455 was a great help in getting the car right in short order on a very hot humid kansas night at test and tune. first run was a 12.66 at 109, called Jeff as he had set up my 1050 quick fuel carb and he dialed in my timing and jet changes in short order! result was a 11.99 at 115mph heres the results, 60' times are off but that's under diagnosis. still a lot of fun beings a casual racer. can't help but wonder how much faster the car will be getting it right? thoughts? 12.66 at 109, 1.9545 60ft 12.62 at 111, 1.9528 60ft shaker455 called...lol 11.99 at 115, 1.8281 60ft 12.07 at 115, 1.9024 60ft 12.00 at 115, 1.8253 60ft 12.05 at 115, 1.8365 60ft 60ft times buggin me! |
Congrats man, that is motor-vating !!
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Sounds like a good first time out. Long as you had fun thats all that matters!
67 firebird 62 tempest |
Wow.. great times for those 60 fts... My 12.70 street car will 60 ft 1.65-1.70 with the drag radials and 400 cubes and a 3.73 gear. Your ride still has a load of potential I'd say. Congrats
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
Eric,
A great 1st night out at the track with your new combo! You should post up your video's...my son was all over that! There's more in your combo for sure! Thanks for having me for part of your build Jeff
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Eric
lil more on the combo would help to get to diagnosis.
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y |
Good ET's!
What kind of tire/slick are you running? For 1st time out with it, not bad. Definitely will be quicker with more testing/tuning.
Heres the combo;
472ci forged crank/6.8 rods/4 bolt mains/canton deep sump pan/sd oil pump, comp hyd roller .242/.248, .594/.618 with 1.65 roller rockers, butler race port 85cc round port e heads 308cfm @ .600, port matched victor intake with 1" wilson tapered spacer, 4150/1050 quick fuel carb set up via shaker455, dougs 1 7/8 headers, manual valve body th400/neal chance 9" 3,000 flash stall converter, moser 12 bolt 4.30 gears, 29.5 x 10.5 hoosier drag radials, rear sump fuel tank, 8an tank to carb with holley 150hp pump. 90/10, 50/50 shocks, right rear air bag at 5lbs, rear sway bar, no front sway bar. seems others with less combos are always runnin faster! lol , thanks for any help. |
It's all here: """"".butler race port 85cc round port e heads 308cfm @ .600, port matched victor intake with 1" wilson tapered spacer, 4150/1050.""""""
What was Initial ADV & Total ADV, or was timing locked-up at TOTAL ADV? What Octane fuel did you run? Great MPH for the 1st time out. Time to focus on suspension
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
What's your shift point?
Have a pic of an ET slip? I'd say a higher stall converter would help a lot.
Pretty "soft" 60' times for the combination of parts. It should EASILY go in the 1.7's if not 1.6 60' times with that gearing/converter.
Tune is still off some, IMHO, and must have been WAY off the mark to find 6 tenths and 6 mph and not much change in 60' times. I'd keep hammering away at the tune as well, and working on launch technique, getting heat in the tires, etc, to get the 60's times down some. A 3000 flash converter should do fine for what you are doing. Unless you've already tried it, I'd try leaving off idle to help it lift the car and hit the tires harder, in lieu of loading it up on the starting line.......Cliff
What track in Kansas?
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Nice tuning.
What rpm through the lights? |
Searching for more...
began with 18 deg initial/35 total timing in by 3,000rpm, carb jetted 81/90, 12.60's at this set up.
changed to 22 deg initial/35 total by 3,000 rpm, rejetted to 85/94, resulted in 11.99 to 12.05 shifted at 6,150 ran vp/c12 fuel my track is kansas international dragway didn't get a glimpse of the tach thru the traps but my shift light is 6,150 and it did not light. my 12.62 run had a 330ft of 5.4188 my 11.99 run had a 330ft of 5.0723 working on scan of slips and video post thanks for any and all assist. Last edited by JUDGE3; 06-18-2012 at 12:25 PM. Reason: add data |
X2 couldn't agree more!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
You may want to make mention that you uncorked your headers at the track and didn't mention that until the next day. Yeah.. that can throw the tune off a bit..... But that's okay you called after the first run and you saw lean plugs... We were in process of jetting up until it slows....night goes fast.
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 06-18-2012 at 04:58 PM. |
Jeff, Thanks for all the help. my combo wouldn't be where its at without it! |
Leave the exhaust on if it's tuned for it. I love the sound of my cars exhaust through the pipes going downtrack... Not a hp killer either...
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
