Old 06-02-2012, 01:01 AM
Steve Hoog's Avatar
Steve Hoog Steve Hoog is offline
formerly Steved400
Send a message via Yahoo to Steve Hoog
Default Shay Hoog Becomes a Pontiac Man Today
My 16 year old son just got his first Pontiac today, it's going to take a bit of work but it is in pretty good condition so far.
The Following User Says Thank You to Steve Hoog For This Useful Post:
Old 06-02-2012, 01:12 AM
68lemansman's Avatar
68lemansman 68lemansman is offline
Welcome to the Pontiac Family! They all need some work to get them where you want them. Gotta start somewhere.
Jason
1968 lemans :In progress!
1970 Bonneville 455 HO convertible (survivor)sold
1969 firebird
Old 06-02-2012, 06:57 AM
Rob B's Avatar
Rob B Rob B is offline
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 06-02-2012, 07:34 AM
The Boss's Avatar
The Boss The Boss is offline
It's about time!
And go racin' in the street.
The Following User Says Thank You to The Boss For This Useful Post:
Old 06-02-2012, 09:20 AM
stu72's Avatar
stu72 stu72 is offline
x2
Old 06-02-2012, 10:07 AM
Steve Hoog's Avatar
formerly Steved400
Cleaning it out....
Old 06-02-2012, 10:12 AM
Steve Hoog's Avatar
formerly Steved400
And we will finally use the Weld wheels I bought from PY user Mr. Pushrod I think? Almost a decade ago.
Old 06-02-2012, 12:08 PM
Good looking car!
former." --Albert Einstein
- Winston Churchill
The Following User Says Thank You to mike nixon For This Useful Post:
Old 06-02-2012, 04:11 PM
Steve Hoog's Avatar
formerly Steved400
Well if this was a 69-71 GTO body I would be screaming for joy at this point; but since it's not I'm scratching my head. So to the Ventura experts I now ask what does this probable factory stripes mean?
Old 06-02-2012, 07:11 PM
se428bandit's Avatar
se428bandit se428bandit is offline
A sprint had a factory stripe. Does it have buckets seats,sport mirrors and a sport wheel?
Old 06-02-2012, 07:25 PM
Steve Hoog's Avatar
formerly Steved400
Bench, regular wheel, and right mirror holes in door covered over with puddy. Regular on Left. Cut pile carpet.
Old 06-03-2012, 08:45 AM
74gto's Avatar
74gto 74gto is offline
From what I can make out of the front end, it is a 73. Most 73's had the split grill. It looks like your car has the fiberglass front header pannel with the egg crate grills. These grills are different from 74, as the 74 has a honeycomb grill pattern. The 73 nose is flatter than the 74. Show us a better picture of the front end, and we can verify that for you. 74 header pannel is steel, not fiberglass. Can't see the front bumper good enough to tell if it's correct. The front end along with the door stripe leads me to believe you have a Ventura Sprint, but you would have to send into PHS to verify this.
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 06-03-2012, 10:37 AM
Steve Hoog's Avatar
formerly Steved400
Regardless of whatever sheetmetal is right or wrong, it is a 74. Also to my puzzlement it has Custom call out tags yet the VIN says regular Ventura.
Old 06-03-2012, 10:40 AM
Steve Hoog's Avatar
formerly Steved400
Also, are the V8 frame engine mounts the same as 1st Gen F Body?
Old 06-03-2012, 11:06 AM
The front sub frame is the same as a 1st gen,which is perfect for a 428 and long branch manifolds.
Old 06-03-2012, 12:24 PM
The Boss's Avatar
So what's the plan?
Old 06-03-2012, 04:11 PM
Steve Hoog's Avatar
formerly Steved400
Sanding and beer, or beer and sanding. Not sure which sounds better.....
Find frame motor mounts, order crossmember when I get to work tomorrow and then stick that 326 in it.
Old 06-03-2012, 08:29 PM
Steve Hoog's Avatar
formerly Steved400
A couple of more questions
On rear wheel, would a 15x8 and 4.5 back space work or does it need 5.5 back space and or only a 15x7 to get in the tub.
Is this rearend the same as the 1 Gen or 2 Gen F Body rears; or maybe unique to the X Body?
Old 06-03-2012, 08:35 PM
It is the same width as 1st gen but the 1st gen has a 8.2 and '72 and up Ventura's had 8.5 10 bolts.
Old 06-03-2012, 08:52 PM
Steve Hoog's Avatar
formerly Steved400
Nice, thank you.
I think I already knew the answer to the wheel and just didn't think; I stuck one of my Corvette rims on there and it was fine.
