Old 05-27-2012, 10:55 PM
hottrodd's Avatar
hottrodd hottrodd is offline
Default Gto concourse judge or 66-67 Gto expert, have ? On vinyl top trim??
Did the 66-67 vinyl top option car's have any type of metal or plastic trim that went on top of the vinyl on the inside of the drip rail gutter??? I not asking about the outer drip rail trim.
I have a set of nos aluminum/ or possibly s.s. Trim,. That was in a original gm box that was falling apart & mice had chewed up, there was no part # I could find on the remaining box, I did find a piece of tape on the trim stating it was" inner driprail trim/ 66-67 vinyl top Gto".
I have layer it in the , it fits fine, looks like u would lay this trim on top of the vinyl in the driprail, then when u installed the outer driprail trim it locked the inner driprail trim in place?????
Does anyone know or have any documented info on this?
Or anyone have a non-restored 66-67 Gto, lemans, tempest with the original vinyl roof with the original trim , do they have any trim in the inner gutter laying on top of the vinyl trim????
Old 05-28-2012, 08:22 AM
Andre's Avatar
Andre Andre is offline
I distinctly remember this on my friends low mileage 67 Lemans that he got back in 1980.
It was a beaded piece that was made of plastic. Might have been clear originally, but by then it was starting to shrink and turn white.
It seemed like it was put in last, and was a friction fit with the aluminum drip rail trim.
I don't know what the purpose would have been for. Maybe on vinyl top cars, the aluminum drip rail fitted ont top of the vinyl cause the edge to cut your fingers, so this prevented that? I can't be the only one that remembers this.
Old 05-28-2012, 08:26 AM
400 4spd.'s Avatar
You aren't. Mine had the same piece, kind of translucent white.
Old 05-28-2012, 11:08 AM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
My '67 still has small sections of the plastic filler trim on it, it appears to be silver or clear at one time.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 05-28-2012, 12:17 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The 66 Reef Turquoise Survivor with Black Vinyl Top that sold a few months back on ebay (Colin's Classic Automobiles) had a perfect pic of the "Silver" colored plastic strip that pushes down into the gutter run. I have seen these in various conditions on Original Vinyl top cars.
Old 05-28-2012, 12:49 PM
67 LeMans 326's Avatar
67 LeMans 326 67 LeMans 326 is offline
I have a friend who has an all original 67 LeMans vinyl top car and his car does in fact have these pieces as well. In fact I too was going to take pics and post them and inquire about this as I had never seen this before...
Old 05-28-2012, 05:39 PM
oldgoat16's Avatar
oldgoat16 oldgoat16 is offline
Post trim insert
hottrrod, I also had a 66 that was a factory vinyl roof car and when we stripped the top off that insert was impossible to remove without destroying it, it was made of either stainless or aluminum if i remember correctly, I would say those are rare pieces to find for someone..
Old 05-28-2012, 08:16 PM
jd66 jd66 is offline
Default vinyle top trim
my 66 GTO that i bought as a demo in oct. 66 came from the factory with a vinyle top and yes it had the small stainless strips inside the drip edge on the top, my body man re-installed these for me with the new top and paint job, look pretty good but not as good as the original install from the factory, he said they where a bear to install, if you have a car that has these and you want to put on a new top remove the aluminum rails and lightly tap the metal strip on the top outward to release the stainless strips i've removed a couple sets like this in the past. jd grim
Old 05-29-2012, 08:12 AM
Andre's Avatar
So were these stainless, plastic, or both, and what purpose did they serve. I distinctly remembe the plastic ones getting loose and flopping around.
Old 05-29-2012, 06:22 PM
Ducks Goat's Avatar
I think some of you guys are talking about two different things. Vinyl top cars had stainless trim along the driprail just like painted roof cars. Now what the OP was discussing was the plastic trim that filled in between the stainless and the vinyl top material. This was on '67 and earlier models only I think, I believe the '68 up cars had vinyl wrapped over the driprail so the filler wasn't needed. I'll snap a pic of mine and post up.
1967 Lemans convt
Old 05-29-2012, 06:41 PM
Ducks Goat's Avatar
See if these help. Sould be a continuous strip, but mine have broken up over the years. I'd love to have a set of these if any of you guys have some to get rid of.
ID:	286053   Click image for larger version
1967 Lemans convt
Old 05-29-2012, 09:43 PM
hottrodd's Avatar
Jd 66, you r exactly talking about the pieces I have, they look like the pics " ducks goat" posted, but they are stainless steel, I'll try to post pics of the pieces, I'm not go at posting pics, I'll send them to old goat 67, se if he'll post them for me tonight.
Jd66, in the metal sets you removed & installed, were they glued to the vinyl, or just pressure fit??
Thanks for all the info so far,
Old 05-29-2012, 09:47 PM
Old Goat 67's Avatar
Waiting.....
Old 05-29-2012, 09:48 PM
My originals were plastic.... long gone, came out in pieces.
Would love to find a source.
Charles
Old 05-29-2012, 10:16 PM
hottrodd's Avatar
Charlie, just put the pics in the dropbox file, I try to get as good of pics that I could, I layed one in the gutter to show what it looked like installed, & a few closeup of the trim
Old 05-29-2012, 10:46 PM
Here are the pics J sent me.
How this guy keeps coming up with parts I can't possibly find, I just don't know!
Charles
Name:	car part, park 2-28-12, 67 gto vinyl top trim 194.jpg
ID:	286088   Click image for larger version
Name:	car part, park 2-28-12, 67 gto vinyl top trim 176.jpg
ID:	286089   Click image for larger version
Name:	car part, park 2-28-12, 67 gto vinyl top trim 177.jpg
ID:	286090   Click image for larger version
Name:	car part, park 2-28-12, 67 gto vinyl top trim 180.jpg
Old 05-29-2012, 10:58 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Charles
Wow, I've never seen any that have come out that well. In my experience, 64 & 65 were the stainless pieces, (like those pictured) and 66 & 67 were the hard plastic. Evidently they were used to hold the vinyl top down in the gutter; to keep it from 'curling' up. Over the years when these vinyl tops were replaced these pieces were just thrown away.
These may have even been discontinued in 68 and newer. I know that I've got a 71 El Camino with the original vinyl top that does NOT have these pieces. (The vinyl top is curling up in the gutter on the drivers side!) Maybe someone with a 68-9 with an original vinyl top will chime in.
Old 05-29-2012, 11:00 PM
hottrodd's Avatar
Thanks Charlie, I didn't press the trim down into the gutter channel, afraid I won't be able to get to out without damaging it, the piece are straight, but very flexible , they easily conform to the driprail shape.
They are 55" long, 1/4" wide.
So what do u guys think?????
Could they have used s.s. In early 66, then switched to plastic?
Or did some plants use s.s trim, others use plastic??
Would really like to know if they are correct ?????
Old 05-29-2012, 11:07 PM
hottrodd's Avatar
So you think this trim was actually used in 64-65???
If that is the case, wonder if there was a switch over in 66 or 67 , & they used up remaining s.s. Trim then went to cheaper plastic????
Old 05-29-2012, 11:30 PM
Jerry H.'s Avatar
Oh yes. I distinctly remember pulling the stainless trim out of the gutter on a 65 that I restored back in 1981! It took me forever to get it out and I really made a mess of it!
And I would say your theory is a good guess. Or maybe one plant used stainless and others used the hard plastic. I know the one we did a couple of years ago was built in Kansas City IIRC. and it had the hard plastic.
