Hello
I'm in the process of rebuilding a 69 ohc 6 1 bbl and am adding the sprint cam, intake and exhaust. Is there an aftermarket spring setup that mimics the sprint setup? Thanks for any help. Dan
1969 t/a tribute convertible restoration underway! |
closest is the 66 GTO or 421
theres plenty of aftermarket springs with same specs as stock Sprints. What valves are you using? keep in mind that installed height plays a part in spring pressures
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
![]() Quote:
Dan
Spring requirement is remarkably "stock like" for 7500 RPM activity.
![]() Quote:
the 250 4 bbl springs were made weak so they would float when revved above 5500. 66-7 was another story
Since the 80's. You do have a point. My Sprint had a 280 degree cam done by MOON. It rev'd fine but I don't know-for-sure that it has stock springs. They looked stock, and original owner never talked about changing springs. The valves were stock. I spun the crap out of it and can say there was no hint of float. Springs I had looked like stock non-ram air 400 springs.
Are the 66 GTO/421 springs you mentioned the same dual springs setup as the OHC sprint? What are the specs of the springs or where would I find that info. Which aftermarket places carry them?
![]() 69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
