pumpless Methanol/water Inj
For guys running CO2 and want to run Methanol or water Inj. Pat Musi has come out with a new system. Just sharing some info.
http://www.yellowbullet.com/forum/sh...17#post8398217 |
Bryan I ran self regulated water/alky with boost pressure. Pretty simple and it worked very well.
IMO exhaust pressure could do same thing if you made a small "scooped" entrance inside a pipe or collector facing exhaust charge to pressurize the tank. I used system same as figure 70 in pic. Tank has to be below inlet to prevent siphon. Window wash fluid was all I needed for 22 psi on mid to late 70's pump premium (about 91 octane then). Compressor atomizes mix really well. If I were doing NA with ex pressure Id inject just above carb venturi. You can bleed some pressure to delay activation. I have a better scan somewhere or could dig out the book and rescan if needed. Also including pic of the start of the tank I'll be using on my project. Last edited by BruceWilkie; 03-27-2012 at 08:48 PM. |
This is a fresh scan. The actual file is fine when opened with "paint". I can email it if you send me your email address.
yea i have seen those drawing before Bruce. Just havnt seen anyone useing the C02 as the supply thought it was a different idea. Not saying its a New idea. Just a new system.
It looks like a good way to go especially if you already have an airshifter. There are
disadvantages to the basic system I posted related to plumbing and intercoolers where injection has to be into pressure side or in the intake for distribution concerns. I prefer simple when I can chose it. Main reason I posted was to let others know there are several ways to get the end result. |
