Old 02-21-2012, 01:24 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
Thumbs up The Inland Empire GTO Club dyno day @ HK Motorsports Dyno Shop
1972 GTO
http://www.youtube.com/watch?v=LFuBh...5&feature=plcp
1966 GTO
http://www.youtube.com/watch?v=wYRLZ...eature=related
1964 Wagon
http://www.youtube.com/watch?v=kGgOT...eature=related
1967 GTO
http://www.youtube.com/watch?v=192_Q...eature=related
1968 Firebird
http://www.youtube.com/watch?v=J-Bd08M33Yk
http://www.hkmotorsportsdynoshop.com/
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 02-21-2012, 01:56 AM
harry k's Avatar
Smile
Old 02-21-2012, 05:43 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
All sounded rather healthy Harry, BUT numbers with mild description of combo's would be helpful. Great sounding Pontiacs anyway.
Old 02-21-2012, 05:55 PM
critter's Avatar
critter critter is offline
Was that pin head Bruce Rhoads there with you? That looks like him in the picture and that sure looks like his 67. Tell him I said hey.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 02-21-2012, 08:44 PM
69FIREBIRD76MM's Avatar
Default dyno results
71 gto-455---350+hp to the wheels
66 gto -455----315
67 gto--455----350+
64 wagon 428. kre heads, rpm===360hp+ full exhaust, 410+ open exhaust
Old 02-21-2012, 11:59 PM
SupergasDil's Avatar
Hey Chris, Yeah that was Bruce Man and his 67.
Harry, Thanks for posting the videos. Very Cool
And we proudly wear our club colors here in Oklahoma too. The IE GTO Club started in 1985 has members in So Cal, Pennsylvania, Idaho, Arizona, Oklahoma.
Old 02-22-2012, 12:19 AM
nachomax's Avatar
nachomax nachomax is offline
1968 Firebird -- 289 rwhp
Old 02-22-2012, 08:11 PM
lust4speed's Avatar
Those videos came out much better than the mine did with the stationary camcorder.
Dil is being way too modest - he founded the club and was the dictator, I mean "president", of the Inland Empire GTO Club for many years.
The '72 GTO is owned by Rick Haney, and is an original HO 455 with the rock-crusher 4-speed. It retains its original engine, trans, and rearend. The engine had come close to being destroyed by a speed shop down in Los Angeles - and it quickly earned the name "The Engine from Hell" as we got into it. You name it, and the shop had screwed it up from a crank cut out of index with egg shaped journals, a cam so tight in the bearings that liquified the babbit, and decks that were .004" low on each end. We obtained a new crank from Ken Brewer, a custom HFT cam from Ken Crocie and had the block square decked. The 7F6 heads were milled .048" to raise the compression up to 9.3:1, and the heads were home ported and new springs and SS valves were installed.
The 66 GTO owned by Tim Rankin has a 428 with 6X heads, and also has a custom SFT cam from Ken Crocie. Tim is still chasing a few demons trying to get the horsepower up, but he is making progress. We're coming to the conclusion that while the heads were ported before he got them, the port work has actually subtracted horsepower from even stock heads. I'm sure it won't be long and the heads will be history.
The 64 wagon is owned by Jim Miholick and is a very cool ride. It also has a 428 with Kaufman heads hooking up to a Richmond 6-speed trans. Jim had an oil burning problem on the trip to and from Harry's shop and Jim has now traced it to a combination of aluminum valley pan and a defective PVC valve. This is the second bad valve we have come across, and both have been AC valves from one of our large Pontiac Suppliers (not PY).
The 67 GTO is owned by Bruce Rhoads, and has a 428 short block that went from Bruce, to me, and back to Bruce. JE Sportsman pistons and BME aluminum rods. Heads are port matched 96's that are gasket matched but no port work. He's running a big SFT cam that he got from Dil that seems to work very good despite the low 9:1 compression. This combination runs much better than the sum of its parts.
It's always enjoyable spending the day down at Harry's shop.
Mick Batson
Old 02-23-2012, 04:53 PM
harry k's Avatar
Thumbs up numbers & new vid
sure here you go .
[quote=SupergasDil;4558942]Hey Chris, Yeah that was Bruce Man and his 67.
Dill next is your turn for your gaser to get on the dyno
[quote=lust4speed;4559517]Those videos came out much better than the mine did with the stationary camcorder.
here is Micks vid>>>http://www.youtube.com/watch?v=IQaaTHKtiEM
Rick arrived with blue line & left with red line
run notes:HK TUNE
455 H.O. 4-speed M-22 3:55 rear end. Bored .040 over
1.65 rocker arms. cam:
428 .030 over
custom grid cam 244/253 w/1.6 rockers
HK tune
428 ci, solid roller cam (dur = 242 254 @ .050< lobe sep 110 degrees, CR 10.5 (KRE alum heads), Tremec 6-spd manual, 3.42 12-bolt posi
open cut outs
96 HEADS RA iv VALVES
CAM: 605/589..254/259@.050..112* SOLID(1.65 ROLLERS)
9.3 COMP..DEMON 850 CARB
RPM MANIFOLD
3.36 R.R
11" 3600 STALL
T-400
ELECTRIC FUEL PUMP(140)
OPEN CUT OUTS
NOTE THE PONTIAC BLUE FUEL DRAIN CUPS !!!!
