Old 01-05-2012, 08:08 PM
spb350 spb350 is offline
Default Where does this dash light/plug go on my 73 dash?
I am reinstalling my dash and have an extra light/plug that I'm not sure where it goes. Perhaps I have another light plugged in where its not supposed to go? It lloks like it could go in the tach/speedo housing or the heater housing. Any help is apprecisted. Thanks
ID:	269516   Click image for larger version
73 Trans Am Red/White #'s match 4spd...... sold
69 Firebird 400 conv #'s match AT Blue wht/wht
06 Vette conv Red/Red/Blk
Old 01-05-2012, 08:11 PM
2manyT/A'S's Avatar
That one goes into one of the dash light holes in the lower right side of your speedo cluster.
It actually transmits light through fiber-optics to your ashtray for illumination.
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
Old 01-05-2012, 10:32 PM
So the other end of this ends up at the ashtray?
Old 01-05-2012, 10:34 PM
2manyT/A'S's Avatar
That's right.
Old 01-29-2023, 04:05 PM
cnc's Avatar
cnc cnc is offline
I know this is SUPER old but Any chance u have a Pic for location of the bulb in the cluster housing....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 01-29-2023, 06:30 PM
Formulabruce's Avatar
Furthest to bottom right as you face front of gauges, must be a parking light socket.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 01-29-2023, 07:57 PM
Held for Ransom's Avatar
Funny, mine was in the upper, passenger side.
Another question.
Chris, or anyone else, does your '73 have pins or screws holding the lens cover on? And, date of car or printed circuit?
So long, farewell.
Old 01-29-2023, 09:22 PM
cnc's Avatar
cnc cnc is offline
Another question.
Ok couple options then..
I have changed out the cluster of this car as it was originally an idiot light car so the circuit board has been changed out and I re pinned the harmonica connector to get everything to work, as for the lens I’ll take a look tomorrow …..I have the original cluster too from the car still or pretty sure I should have it let me check tomorrow…
Old 01-29-2023, 09:27 PM
IMO, not a couple options.
Bottom 2 on the right are brake and seat belt lights.
So long, farewell.
Old 01-29-2023, 10:53 PM
cnc's Avatar
cnc cnc is offline
Yes looking at a cluster pic the lower area would be warning lights looks like upper section like your pic
Old 01-29-2023, 11:37 PM
Another question.
HFR's pic is correct as the Bottom trio are NOT parking light on 73
Old 01-29-2023, 11:54 PM
unruhjonny's Avatar
IIRC the earlier clusters used those funny pins to hold the lens on, the latter ones were the 1/4”(?) screws
1970 Formula 400
Old 01-30-2023, 08:20 PM
cnc's Avatar
cnc cnc is offline
Ok here is what I have original cluster screws to hold the lens, this pic answered my own question on the fiber optic bulb position and that's the sticker that is on it...
ID:	606378   Click image for larger version
ID:	606379   Click image for larger version
Old 01-30-2023, 08:25 PM
cnc's Avatar
cnc cnc is offline
Here is what's in the car same deal screws for the lens however the fuel volt is clips I'm not sure where I got this from might have come in the car in a box when I got it.
ID:	606381   Click image for larger version
Old 01-30-2023, 11:13 PM
unruhjonny's Avatar
well then, I stand corrected
1970 Formula 400
Old 01-31-2023, 05:26 AM
The pins were used for the FUEL/VOLTS package I think for all years.
Chris, you said that the cluster was an upgrade by you, so I can't include that unless you had the date stamp showing the date.
Jonny, that would be for a '74 and I know they switched sometime in the '73 model year.
So long, farewell.
Old 01-31-2023, 10:14 AM
unruhjonny's Avatar
i meant to go dig out my clusters;
iirc I kept them original, or when I repaired one, I intentionally put it back as it was.
1970 Formula 400
Old 01-31-2023, 04:04 PM
unruhjonny's Avatar
First, thanks for this post!
Hopefully those of you who recognize my posts know that I am all too happy to share my recollections, or observations - but I am by no means a professed expert - so if someone suggests I am wrong, I will generally back of - unless I have good reason to be stubborn
I try to always be clear when I am going off memory, versus my source, or if I am (which I do on occasion) offering my opinion.
Second, I went and check my remaining small collection - here is what I have found;
My findings absolutely back up HFR's prior post.
All my secondary pods (fuel/volts) that I have use the clips - this includes the couple "UNLEADED FUEL ONLY" (1975+) pods.
  • ZF (1970 dated) rally gauges w/tach; clips (x2)
  • ZE (1970 dated) rally gauges w/clock; clips
  • ZD* (1970 dated) standard gauges w/clock; clips (* = The sticker is faded, but I am pretty sure this is the gauge package code)
  • ZA (1971 dated) standard gauges; clips
  • ZX (1974 dated) rally gauges w/tach; screws
Even though my ZA gauges dated as being 1971, I consider them a part of my complete "collection" of 1970 gauges (I think I have all versions).
EDIT:
I looked for a listing I made here years ago for a spare set of 1973 rally gauges w/tach that I had, but it, and the attachments are gone - but I found it in my personal files; the printed circuit appears to be dated Dec 12th, the case is stamped what appears to be March 1973, and it too had the clips.
1970 Formula 400
Old 01-31-2023, 06:29 PM
Oops, I misread the date on the picture that cnc posted and said Jonny posted it. It actually reads 1-25-73 and apparently has the screws.
Thanks.
So long, farewell.
