Are all GM 12 Bolts the same?
My 66 GTO currently has a 12 bolt rear end that matches to a 1972 Chevelle. It’s a 410 ratio, and for years I’ve been wanting to take it down to a 355. I’ve been watching e-bay and have found 2 gears that I am interested in. The first is a Richmond, a brand I’ve heard of, and this is the link:
http://www.ebay.com/itm/Richmond-Gea...item5ae2e40b01 If I buy this one, I can add a rebuild kit for about $100. The other is a complete kit with a Motive gear, a brand I am not familiar with. http://www.ebay.com/itm/GM-8-875-12-...item3ef3ac743f I know a retired mechanic who said that he would install the gear reasonably. My question is 3-fold. 1. Will these gears fit? 2. Which is the better gear and deal? 3. What do you think reasonable is for installing the gear? Thanks, Dan
Plans are what you make when you want to hear God laugh!! |
I was under the impression that a 4 series gear set uses a different carrier assembly than a 3 series gear set meaning you would have to change the carrier to go to a 3:55.
Thanks melwff. I did a little more research after your post, and there are 4:10 gears available for both the 3 and 4 series carriers. So I will have to figure out what carrier I have in there before I proceed. If I'm lucky it will be a 3 series, whereas I can just replace the gear, if not, it will involve a new carrier also.
Just make sure which carrier you have and the gears fit it. They make a 3.73, 4.10 gear that fits both 3 and 4 series carriers.
The casting #'s for chevy 12 bolt posi units are,2 series ED32088,3 series 30140PM1,and 4 series EDB30174.
Thanks A Schab. Where on the differential do I find these casting numbers?
The EDB xxxxx casting number of oem Eaton posi carrier is on the rh end of the carrier. Or with the posi carrier loose & the carrier setting on a table on its left hand bearing boss, wou will see it on the top.
"174" is the most common 4 series Eaton 12 bolt posi, & will not take a 3.55 gear set, but will take richmond's special thin 3.73 gearset. "140" is the oem Eaton 3 series carrier & will take GM & aftermarket 3.55 gears. Most well used Eaton posi carriers will need side gears & spiders replaced, always something to consider.
I've owned 2,3,4 series 12-Bolt Posi's & the Strange 12-Bolt 4-series Spool.
Also, used a 2-3series spacer. I'm sick of 12-bolt rears. I'm impressed with the Big Car (Impala, Kingswood estate) 12-bolt posi, and the Dana-60. Big Car 12-Bolt is capable of Highway gears whereas Dana-60 is not. My point: Strange Engineering will drop-ship a 3.54:1 Dana-60 with Pro-posi&35spline axles, 1350U-Joint, & chrome cover to your garage door for $2100 or so. Last edited by Half-Inch Stud; 10-27-2011 at 08:06 AM. |
Good info HIS. I've got that much invested in my 8.5 ten bolt. Next time I blow it up, I'll be shopping for something a LOT stronger that I can just bolt in.....Cliff
Dan Debones152;
Stock GM 3.55 gears on the original posi are probably what you could aim for. One more idea: The 8.8 Lincoln Continental (Mark 6-7?) Disc-Brake rear may bolt-right-in to the 66 GTO , and be axle-axle width compatible. 8.8 rears look quite like a 10Bolt, disc-brakes usually 3.27 posi, have 5"pattern and...............Half-Inch Studs |
