Old 09-10-2011, 04:07 PM
BrandX's Avatar
BrandX BrandX is offline
Default Who's badass car is this and would like more info about the combo?
www.MidwestStreetCars.com
Butler Performance
Quillen Motorsports
Don Dial Race Cars
Old 09-10-2011, 04:09 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Might be Goatracer if he painted the fenders to match the car.
Don't worry its not fast.
Nah, I think it is that other slow CV1 mustang.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
Old 09-10-2011, 04:34 PM
Tom Vaught's Avatar
Boost Engineer
Goat Racer is probably the only Pontiac Powered Mustang in the country so would not bet any money that it was someone else.
STREET RACER in Detroit. Being a Ford, lots of Chevy suckers. Being Pontiac Powered even more Chevy and Ford suckers. Being on spray with a tunnel ram and Dominators on a Pontiac Engine, LOTS of Ford and Chevy suckers. "Pontiacs don't run and wid that chit on there, bring it Dog"
Tom Vaught
ps We will not even get into how many extra lengths they want to give with the CV-1 heads on the engine. (;>) EHTTTMF
Old 09-10-2011, 05:27 PM
Hooter's Avatar
Hooter Hooter is offline
There's a guy near Kansas City with a Pontiac powered Mustang too. Might be his if not Goatracer's. It's also CV-1 powered.
67 Bonneville ragtop
Old 09-10-2011, 05:56 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by BrandX View Post
a smart person since its light and the mustang suspension works real good.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 09-10-2011, 07:35 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
That car is wrong in so many ways that it is right.
Old 09-10-2011, 08:46 PM
goatracer goatracer is offline
He's a member here...PM505, I think...badass radial car. Check out Goin Performance on YouTube.
Hooter got it...He's outta Kansas City.
Bryan
Old 09-10-2011, 09:04 PM
Haha, yep, the score board don't lie...148mph, that's all she's got. As soon as you're ready, we can meet back at Norwalk.
You still shootin' for end of this month?
Bryan
Old 09-10-2011, 10:03 PM
David Holmberg's Avatar
J.C. You has/had a Pontiac powered Mustang too.
Old 09-10-2011, 11:48 PM
Dave81461's Avatar
Dave81461 Dave81461 is offline
Kendal Goin of Kansas City. IAII 505, CV1 heads with a glide.
Old 09-11-2011, 06:45 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Talking imposters....
the only...REAL er..ahuh pump gas, stock block, iron head, ponchostang was campaigned by yours truely. Those new fangled, aftermarket block and head cars are a abomination to the brand. How dare those guys run anything but stock stuff.
and, there is only one acceptable oem way for the arrowhead to be affixed to the hood...the only correct thing i see is that it is the right color.
ID:	256330   Click image for larger version
Old 09-11-2011, 09:44 AM
LiL Jack's Avatar
Bryan
I hope you have gone faster then that 8.50@ 162 on a 32 pill!
Sad,just sad.
EHTTFMF!
Old 09-11-2011, 09:45 AM
455firebird1969's Avatar
So what does your Ponchostang weight? What times have you run with the OEM parts?
Just curious...
Old 09-11-2011, 11:06 AM
7T2 7T2 is offline
Lightbulb
x-
i was with kendall this past weekend at rogersville where he posted the second fastest et in the drag radial class. pm me for his contact info,
jim
Old 09-11-2011, 11:38 AM
Originally Posted by 7T2 View Post
x-
jim
well what did it run??
1.079 4.559 153.23.
3100 lbs
T2TTFMF!
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 09-11-2011, 02:18 PM
LiL Jack's Avatar
U need ur secret cv1 decoder ring to get that info.
Old 09-11-2011, 02:58 PM
LiL Jack's Avatar
Old 09-11-2011, 04:25 PM
gene simmons gene simmons is offline
http://www.youtube.com/watch?v=DESnb...eature=related
In the description from one of the other videos 2010 showed a 5.58
From Aug 1 2011, no et
http://www.youtube.com/watch?v=K6rUU...el_video_title
Old 09-11-2011, 06:27 PM
Sad,just sad.
EHTTFMF!
Certainly nothing to brag about, you got that right. Now that I know how forgiving my chambers are, I can put some timing back in it.
Just worry about gettin' your junk back together, I'll worry about gettn' my combo dialed in...safely.
Bryan
Old 09-11-2011, 06:41 PM
Last I heard more MPH than ever over old E's on less N2O and touching best ETs ever(5 teens) but fighting putting the power down. I know head and manifold swap alone was worth 35 hp NA at same rpm and on same n2o tune as previous, it was up about 80HP and climbing. Initial break in earlier this year 1047hp at 6500rpm at the back tires with a 300 single system fogger, with the curve still on the rise. he said thats 80hp more than the e heads with everything else exactly the same.
35hp NA at the wheels at same relatively low 6500 RPM isnt bad for just a head/manifold swap.(These are out of box heads/intake. Same cam as previous.) Early passes were over 3mph faster than best ever numbers. (on less N2O) Softening the chassis to control wheelstands has kept it from going faster. Also, last I heard, the old convertor may get re-stalled as stall increased considerably after the swap.
FWIW the car weighs 3200lbs.
Due largely to those who criticized without looking at the whole picture, improvements since arent being broadcast.
As a side note though, its rumored that someone is finally stepping up and building a high rpm high compression NA CV1 +500 inch combo that will attempt to take full advantage of a well ported set of CV1 heads.
