repair/rebuild 66 lemans starting... NOW
Alrighty. Guess I will document this somewhat. Here's what has showed up and what it's goin on. Christmas came early woohoo.. And many thanks to my WONDERFUL woman.
Brakes, shocks, floors, seat covers, suspension, carpet, sound deadning, glove box, visors, battery tray, locks, keys, tires wheels, top well, top all here. Time to start working. Just a few pics to start First pic. First time I saw it sitting in his garage.. Floor boards and interior
1966 Lemans (project) 389 tri power 2003 ECSB Silverado w/ 6" lift 2007 HD FLHT. |
Cool, I'm a little partial to 66's. Any more pics, and what are your resto/restification plans?
Mitch Kunath |
Well it is in suprisingly good shape. A little rust in the front floor board so I have new metal for them. All other rust has already been taken care of years ago and was garaged for the last 11. I need to repaint a few thing inside back parchment to match the new interior I have. previous owner painted it all black. New top of course since this one is holey. The convertible frame is in great condition. I guess you could say I'm making it a driver. I will pull the engine and trans and repaint clean up along with firewall and fenderwells that are near perfect. I don't think it's gonna be a body off as it was well undercoated and well it's still well undercoated. Complete front end rebuild with poly bushings and disc brakes. Everthing pulled off will be blasted and painted. After the front end is done I'm gonna pull the rear end and clean polish and paint it and repair anything needed. New exaust. Everything on the car works as is if you can believe it. Then I'm gonna start on the body work. Once it's done if I can't get my inlaw to paint it I will do it myself. Nightwatch blue. Then install the new top (white) and interior (parchment). And put as many miles on it as I can. I want to install the rally pack gauges but that will be later. A good solid cruiser that I can be buried in. At one point someone really cared for the car. The last owner threw a horrible paint job on it but he actlly did more good then bad. He painted EVERYTHING so nothing rusted. He even painted the chrome, thank goodness he didn't sand it first. I like looking at show cars. I LOVE drivers. One fender needs replaced as I'm not sure I can save it (pass side front) rest is pretty darn straight.
That's going to be a sweet ride..., and you have a good woman
CT Gross---66 GTO "Its never too late to have a happy childhood"! I told my dad I was going to stop raising hell, and he called me a quitter! |
Looks like a super nice start. We love pictures, and I just noticed your 'join' date. Welcome to the forums.
Mitch Kunath |
Nightwatch Blue with Parchment top and Interior is a striking color combo. AND it's a 66! Looks like you will have a great car for years to come. Welcome to the Forum.
Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig" |
And welcome to the forum. |
Welcome to the Forum. Glad to see another Lemans owner. Most here seem to be GTO owners. A lot, but not all, of the info transfers to the Lemans/ Tempest models. Many here are very quick and ready to help with info and parts.
Well if I can help any I sure will.
Did I miss anything?
Do the inner tie rod ends have the grease fitting on the end or the back? If it's on the back that will present a problem when trying to grease the joint.
Remember no one is perfect. Everyone's butt has a crack in it! |
fyrffytr1 90's will take care of that problem. The tie rods, center link, idler arm and ball joints are from speedway motors. The pitman had to be reamed to the correct size as the joint there bigger than stock but then again the steering arms had to be drilled to half inch too.
Almost back together. upper a frame adjuster nuts and shims then sit it back on all 4.
Front end back together and sitting on all 4 again. Front springs should settle a little and I still have to install new on the rear but so far I like it. Think the wheels look good to but I may be biased. Like the tire size too. 225 60 15's all the way around.
Looking good! I like the wheels.
Looks very good to me, too. That's going to be a very nice car. Congrats on a "rolling resto". Neither of mine have ever been apart, either. They're meant to be driven!!!
Jeff |
Ok Got the last few parts I was waiting on. Started bleeding the brakes. And to my suprise I needed a new Master Cylinder. Yeah I know. Anyway started looking. Decide on a Disc brake one from a 74 firebird. Bolt it on Fill it up. Bleed it out and went for a short Drive. PERAFLIPPIN GRIN.. Even if I put less than a mile on it. Speedo Works. Brakes work. Trans shift's great. Have a slight wiring problem due to the "alarm and kill switch" the original owner "installed" Probabally why he parked it. It's not charging the battery so with these little problems I haven't been father than walking distance. SO it starts, sounds solid, trans works, brakes work. Next will get the electrical problem fixed. Rebuild alt, replace regulator. And do a longer shake down run. So many things to repair, but NOTHING will compare to the first drive.
Looking good so far. Glad its coming along for you!
Jason 1968 lemans :In progress! 1970 Bonneville 455 HO convertible (survivor)sold 1969 firebird |
I sense excitement!! Looking good.
Looks GRRRRRReat so far. That's be one sweet LeMans when you're done. Congrats on the car, good woman, and it rolling. Also Welcome to PY.
Life as you knew it has just ended in a good way, thanks the good woman and the LeMans.
I have a GREAT WOMAN. But.... I may be pushin my luck a little.. I think she thinks I may be getting a little spoiled.
Nice looking project! My 1st car was a "66 LeMans. Great cars in their own right. Keep us posted on your progress.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald |
