65-69 Lemans & GTO Parts
65-69 GTO/LEMANS PARTS
Location: MARYLAND -------------------------------------------------------------------------------- NOS A/C Delco Plugs 45's sets $60.00 while they last, NOS A/C Delco PVC $7.50, NOS SLOTTED NUTS, CORRECT FOR ENGINE COMPARTMENT- SET OF 5 FOR $20.00 68-69 NOS FRONT WINDSHEILD UPPER STAINLESS MOLDING $150.00 68-69 NOS Driver's side front window molding $90.00 65-66 rear bumper lens $7.00 66-67 miscellaneous moldings early style harmonic balancer parts 67-69 Chrome Valve covers $50.00 PR. 60's fast idle solenoid $100.00 hard to find. 68 Gauge&Speedometer cluster $65.00 68-69 Front window 3pc stainless moldings $125.00 68-69 front lower window reveal molding $60.00 68-69 front fender rear chrome moldings $30.00 pr. 68-69 rear bumper rubber snubbers $30.00 pr. 68-69 alternator bracket that bolts to front of water pump $20.00, 68 1/4 panel side markers, lenses, bezels and housings $45.00 pr., 69-72 Goldenrod/Tan & Pewter/Gray steering wheels crack free $125.00 68 & 69 LEMANS Front Bumper Grill Brackets $35.00 pr. 68 & 69 non hideway frame to bumper brackets $65.00 68-69 door vents pr. $20.00 68-71 gas pedal & bracket assembly $50.00, 68-72 positive battery to starter heat shield tube, 68-72 pair of 1/4 windows $100.00 pair, 68-72 1/4 window glass chrome trim moldings $30.00 pr. fuel escentrics $35.00 68-72 single A/C crank pulleys $35.00, 68-72 emergency brake cable set up $100.00 68-72 emergency brake pedal and bracket $50.00 68-72 rear license plate bracket and holder $35.00, 68-72 rear view mirror $25.00 68 rear bumper brackets $65.00 68-72 front armrest bases black $25.00pr, 68-72 door glass & 1/4 glass regulators $50.00 68-72 hardtop crossmembers primed and painted $90.00 69-72 auto shifters standard & rachet style only a few left 68-72 shifter bezels - 68 2 speed auto bezel, 69-72 3 speed auto bezels $25.00-$35.00 68-72 water thermostat housings $15.00 , 68-72 door hinges $50.00 68-72 points distributors no RA one left $80.00 68-72 wiper tranmission assembly $50.00 69-72 harmonic balancer $30.00, 68-72 blower motors $25.00 68-72 a/c inner and outer boxes with blower motor and heat cores $150.00, 68-72 inner heater box $150.00 68-69 headliner bows $50.00 set 68-72 coils & brackets $35.00 68-72 windage trays $45.00 valley pans $35.00 68-72 stock blue valve covers $25.00 a set 69-72 Gauge&Speedometer cluster $65.00 69-72 Power Front Disk Master Cylinder like new, used during restoration $45.00 69-72 Rally gauge $175.00 assorted stainless moldings, 15x7 Rally II wheels reproductions good condition $175.00 pr. 15x7 Rally II wheel $65.00 69-72 ac & heater dash control with cable $135.00, 69-72 clock delete dash cover $15.00 68-72 door vents pr. $20.00 68-74 power brake booster $50.00, used original Pontiac oil pans $40.00-$65.00 72 & 73 400 SHORT BLOCKS $500.00, 70 WT GTO 400 shortblock $1500.00 Torker intake $150.00, aftermarket chrome valve covers Elderbrock $40.00, a set MALLORY 7MM SUPPRESSION SPARK PLUG WIRES $25.00, AFTERMARKET FLEX FAN $15.00, new points and condensers E-mail at temallory@msn.com
Timmy Mallory |
68 gauge and speedo cluster
Do you still have the 68 gauge and speedometer cluster?
