anti seize as coating?
read on another forum that many have used anti seize as a cheap coating on headers. anyone here done it and what type of results did you have?
1968 - Pontiac GTO |
pretty interesting read but I dont understand why they are doing it. For looks? one guy suggests that hedman states thier paint job is to protect the header in storage. is it for protection? I dont get it?
Nothing about durability. and itd only on the outside what about protection on the inside? Presuming that matters. |
It's basically baked-on, silver colored grease. Whatever....
Jeff |
yea, baked on grease, I can learn to cook if i want that
I can tell you using the spray on for crank journals and cylinder walls for long term storage works really good.
maybe. but it would not be my first choice, not even top five choices and I would never use it as assembly lube, nor would I use it anywhere near the internls of a running engine. and as if thats not enouh to condemn it I would only use ite sparingly on spark plug threads and keep it away from electrodes
make absolutely sure you remove all traces of it from any engine component befor yo assemble it together |
Not talking about for assembly lube just long term storage. Doesn't wipe off as easily as white grease.
Kept my 409 stuff in good shape in my dad's garage for 20+ years even when he kept pool chlorine in there that ate up their bicycles.
Cool idea to try on the lawn mower first.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
