71 T/A hood up in the rear. Bad hinges?
I am having problems getting my hood down where it should be. I have to push the hood down on both sides to make it look right. The other thing is, I dont even have the weatherstripping installed on the cowl yet. I have the hinges adjusted all the way down. Are my hood hinges so worn out that it's making my hood pop up? I am sure others must have had this problem also. I dont want to replace the hinges but rather fix them if they are the problem. Let me know your ideas. Thanks, Walt.
----------- Even a blind squirrel eventually finds his nut's |
If I remember correctly you have to move the hinges up in the back to make the hood go down. I would post this in the body section and see what they say.
Hood hinges are worn out. I have the same problem with my '71 T/A.
you can slot the hinge holes ( up) and put it down in back and up in front to get a better fit. The new repop hinges are based on a camaro hood.
I tried 5 sets of hinges on my formula, which is even more of a pain.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
So are you saying the repro hinges are no good?
I just pulled the springs off my original hinges and have now noticed they seem to be a bit sloppy. How sloppy can I expect a set of hinges to be before they are considered worn out. And is there anyone who rebuilds original hinges? Found these guys online. Anyone used them: http://www.hoodhingerepair.com/index.html
X2. It seems like you would be doing the wrong thing but it pulls the hood right down.
if you see that they have some slop in the rivets, you can have them rebuilt. I had my originals done for a little over $100 if I remember right, and then had them powder coated in a gray phosphate color after I got them back. Only took about two weeks for the hinge rebuild and they work better than new now. Here is the place that redid them: http://www.hoodhingerepair.com/
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
There was thread on rebuilding hood hinges yourself, with a bushing as opposed to the bore it out and new rivet style being offered by the above link.
I wish I could find it...
