Old 07-27-2011, 10:22 AM
MPKind's Avatar
MPKind MPKind is offline
Default Calling all 2D Post Cars: '59-'68 B-Body
Let's get a count of the 2D Post cars on the PY Forum. I started at '59 because that was the beginning of the "Wide Track" era.
Post the following:
Year
Color
Drivetrain
Picture, if you want
My car:
1965
Reef Turquoise
455 (factory appearing for '65), 4-Speed, 3.42 Saf-T-Track
Name:	Catalina 2008-09.jpg
ID:	251503   Click image for larger version
65 Catalina 2D Post
Old 07-27-2011, 01:31 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Year: 1965, second owner, 22,043 original miles, solid no-rust anywhere.
Color: cheap, nasty burgundy repaint by previous original owner.
Drivetrain:
400 block, 4.155 bore, magnafluxed, pressure tested, deburred, etc.
434 Cubes
10.25 compression
Forged 4" crank (All Pontiac)
Forged Eagle 6.8 rods
Diamond pistons
Precision Oil Pumps 60 psi pump
KRE heads
Crower SS 1.6 roller rocker arms
Comp Cams 288 HR
MSD Ignition
Edlebrock Performer RPM
Quickfuel 780 Vacuum secondary carb
Doug Headers, 2 1/2" pipes, DynoMax SS Ultra Flo mufflers, 18" resonators
Flow Kooler water pump and Desert 4 core radiator
Built Turbo 400 trans with Gear Vendors Overdrive unit
Contenential converter (Jim Hand special bought through Cliff)
Moser 9" Ford rear, Nodular center section, Detroit TruTrac with 3.89 gears
R.A.R.E. rear suspension arms and sway bar
New (repo) 8 lug drums and custom-sized Diamond Racing 15 " wheels
Other stuff I can't remember.
I will be removing body from frame this fall to have the frame blasted and powder coated, and to paint the body. Also, I will be converting to front disc brakes and steel rims with poverty caps. I am considering converting to a Keisler 5 speed manual trans, as well.
[SIGPIC][/SIGPIC
Old 07-27-2011, 01:56 PM
Year: 1964 Catalina
Color: Liberty Blue( being changed to Light Aquamarine)
Powertrain: 389 2barrel/ Rotomatic (being changed to 455/4L80E)
Currently, it's in more pieces than I care to think about!!!
Dr. Thomas Sowell
Old 07-27-2011, 02:35 PM
66bonne's Avatar
66bonne 66bonne is offline
Year: 1965
Color: House of Kolor Orion Silver
Powertrain: P-Dude Spec'd and built 496;ProSystem Dominator; Victor intake;Ported KRE heads;P-Dude custom hydraulic roller cam;Moser/Ford 9" 4.10 gears. A few other goodies.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 07-27-2011, 07:25 PM
66bonne's Avatar
Bob/6T5 Cat: Looking good !!
Jim
Old 07-27-2011, 08:08 PM
MPKind's Avatar
I suppose I should have done a "poll", but I don't know how that works...can I repeat post this in the other B-Body tech sections?
65 Catalina 2D Post
Old 07-27-2011, 08:44 PM
6T5 Cat's Avatar
Give it some time your post hasn't been up very long, I'm sure there are more of us out there.
[SIGPIC][/SIGPIC
Old 07-27-2011, 08:48 PM
6T5 Cat's Avatar
Jim
Hey Jim, if your cat runs any faster you're going to have to register that rocket with the the FAA. Bob
[SIGPIC][/SIGPIC
Old 07-27-2011, 09:56 PM
Jim,
Who built your 9"? I've got an estimate from Quick Performance, but I would like to hear
any problem you had with yours.
Dr. Thomas Sowell
Old 07-27-2011, 10:19 PM
62cat's Avatar
62cat 62cat is offline
Default 62 post
i have a 62 post catalina im doing over. theres a tread on here about it. dynoing the engine monday.
Old 07-27-2011, 10:50 PM
66bonne's Avatar
Originally Posted by hurryinhoosier62 View Post
Jim,
The Moser/Ford 9" was built and installed by ProFab Performance in Thonotossa, FL; not too far from me.
It is the Moser M9 housing. Matt at ProFab did a great job on the entire assembly. LOT of work on his part fabricating brackets, spring perches, adjustable upper and lower control arms, beefy rear sway bar, axle length, notched frame for big tire clearance, etc. It was one heck of an undertaking on his part. Wasn't cheap but I asked him to use all top shelf stuff because I only wanted to do this once !! and didn't want to blow a rear end at the strip. But the Catalina launches hard and straight so I've no complaints.
Jim
Old 07-27-2011, 11:07 PM
66bonne's Avatar
Bob - with all those go-fast goodies stuffed in that block - have you been tempted to try it out at the strip ?? How do you like your Gear Vendors O/D unit ? Heard good things about them. If you decide to go to a manual tranny I know someone that may be interested in your O/D unit. Nothing like sasshaying thru the gears in a Darksider !!
Have you picked a new color yet ? I really like that burgandy when it is done right, had a 66 Bonne that color and really liked it. Needs a really good clear coat to make that color pop.
Really anxious to get some good track time with the new P-Dude combo in the Cat. Too hot and humid down here now for any serious tuning but I think we can get in the 10.6s fairly easy. Hope to get it dialed in so we can do some program racing at the local tracks.
I really like what you are doing with your sedan.
Jim
Old 07-28-2011, 05:45 AM
misterp266's Avatar
misterp266 misterp266 is online now
Dark turquoise
Fresh 406 w/fresh TH400
Name:	Home & Clean.JPG
ID:	251614   Click image for larger version
ID:	251615   Click image for larger version
Name:	fresh motor.JPG
ID:	251616   Click image for larger version
" Darksiders Rule "
Old 07-28-2011, 02:22 PM
66bonne's Avatar
misterp266: Gorgeous !! love that color. And the poverty caps really set it off.
Very nice.
Jim
Old 07-28-2011, 06:24 PM
hellerods's Avatar
hellerods hellerods is offline
I am still working on this 64' sedan,getting closer( fresh400/400) . A pair of unfinished Pontiacs in the driveway--how sad is that??
Name:	1964 Pontiac 2 door sedan-- new engine& detail front clip 007.jpg
ID:	251672   Click image for larger version
Name:	1964 Pontiac 2 door sedan-- new engine& detail front clip 008.jpg
ID:	251673   Click image for larger version
Name:	1964 Pontiac 2 door sedan-- new engine& detail front clip 009.jpg
Old 07-28-2011, 10:07 PM
66bonne's Avatar
Not as sad as an empty driveway !!
Jim
Old 07-29-2011, 03:11 PM
Engine-Ear's Avatar
Cool
...heh. I was gonna say, "how FAMILIAR is that?"
Good thread...I no longer own a '62 2311...hope the buyer is treating it properly.
Old 07-29-2011, 11:11 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
63 Cat, has 71 400,t-400, pretty much rust free. Won't be able to keep it thou. Getting some of the bugs worked out. Was going to be a racer. Post cars are cool!
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 08-08-2011, 08:22 AM
misterp266's Avatar
Why aren't you keeping it?
There has to be more post cars out there, let's see some more!
Rob...
" Darksiders Rule "
Old 08-08-2011, 10:56 AM
hellerods's Avatar
I think that there is some bias against us in the "Darksider" family.
