Old 07-22-2011, 11:00 PM
mrtonegto's Avatar
mrtonegto mrtonegto is offline
Default Temp Sensor Location
I will need to add an additional temp sensor to my system for an E-fan.
What about if I drilled and tig welded a bung to the plate in front of my manifold? -see pic.
Why wouldn't that work?
I would save the original plate and simply make one like it or a little heavier gauge.
Tone
Name:	my tripower temp sensor location.jpg
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine"
1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS
Old 07-23-2011, 01:01 AM
Formulabruce's Avatar
why not use the space where the 2 prong switch is now?
Napa sells alot of fan switches. I like a turn on at 179 , gives a little head start on the cooling so it doesnt get to saturation. Keep in mind that its alot hotter on the head so 179 is NOT too early
Old 07-23-2011, 08:56 AM
Ollie's Avatar
Ollie Ollie is offline
The two prong switch is for the stock temp. gauge. mrtonegto probably dose not want to disable the temp gauge.
There is also The flat on the other side of the water cross over, drill and tap there for the sensor.
Its ok to giggle and snicker, Dont laugh and point
Old 07-23-2011, 10:03 AM
mrtonegto's Avatar
I've changed that switch to a tube for my mechanic gauge but, like Ollie said, I dont want to disable that gauge.
Ollie solved my issue in another thread - he showed were there's an alternate position between #1 and #3 on the head.
Old 08-04-2011, 09:01 PM
63gpman's Avatar
63gpman 63gpman is offline
Do you have the link to that thread?
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 08-04-2011, 09:29 PM
mrtonegto's Avatar
See post # 13
http://forums.maxperformanceinc.com/...d.php?t=671720
Old 08-04-2011, 10:01 PM
63gpman's Avatar
Perfect, thanks!!!
Brad Hansen
