Old 06-10-2011, 05:08 PM
ultraman's Avatar
ultraman ultraman is offline
Default trans problen
my trans turbo 350 is jumping out of third when hot one is in my 68 fb the other is in my 76 chevy truck unknown miles on each. does anyone have any ideas ( cliff ruggles mabey) I am at a loss to figure this out!
Old 06-10-2011, 07:10 PM
Cliff R's Avatar
Cliff R Cliff R is offline
The direct clutch is applied, fwd clutch applied, one or the other possibly loosing some apply oil past a seal when it gets hot?
Physically "jumping out of gear" is not possible, unless the leaf spring isn't staying on the "rooster comb" or the nut came off the end of the manual shaft.....Cliff
Old 06-10-2011, 07:17 PM
jakeshoe jakeshoe is offline
Check the governor for wear.
www.jakesperformance.com Racing Automatics and LSx Engine components
Old 06-10-2011, 08:25 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
This has to be year of the broken tranny. Someone have a Chineese calendar that can verify?!
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 06-11-2011, 01:40 PM
Half-Inch Stud's Avatar
"Jumping out of 3rd" is always an indication of clogged filter, low fluid level or both. Make the changes ad report back.
