Old 05-28-2011, 11:07 AM
dlw6767's Avatar
dlw6767 dlw6767 is offline
Default aluminum radiator question
im looking to put a new aluminum radiator in my 65 gto tripower car. both hose connection are on the pass side of the radiator. can i use a rad with the upper hose on the drivers side and find another hose to fit? the aluminum rad with pass side hose connections are 400.00 verses the drivers side ones are a 150.00
Old 05-28-2011, 12:42 PM
steve25 steve25 is online now
yes, but you will likly have to cobble at least two hoses with the right bends and angles in them that you need by coulpling them at some point with a section of the proper size ( OD) exhaust pipe, which is what I had to do for a while with my 671 super charger set up untill about 1986 when I worked for a auto partrs store and went catalog shopping and found a near drop in hose that I only had to shorten at on end by 1.5 inches.
Old 05-28-2011, 01:00 PM
Old Man Taylor's Avatar
Be careful about where the radiator cap is located on the aluminum unit. If it is moved from the original '65 location it might cause interference problems with the hood. That is a problem I ran into on my '64 Tempest.
Old 05-28-2011, 11:11 PM
Scott65's Avatar
Scott65 Scott65 is offline
I used a Summit radiator. Had to make some stands to go in the bottom of the core support to get the height located properly. A friend at work gave me the fans off of his 95 Stratus. Working well so far. It was HOT today (for May) never got over 190, actually cools better around town,won't go over 185 (which is where the fan controller is set). I was able to use a stock '67 upper hose, the bottom required a universal flex hose.
ID:	245572   Click image for larger version
Old 05-29-2011, 02:22 AM
bmidgley bmidgley is offline
Have you considered using the 66 waterneck and 66 upper hose? The 66 neck points toward the driver's side.
Or, since your 65 neck point straight up, use a 66 2 or 4 bbl upper hose. Should work.
Mike
www.pontiactripower.com
Old 05-29-2011, 10:10 AM
Old Goat Racer's Avatar
Any idea what the radiator weighs empty?
Curious, what is the fitting by the #7 spark plug?
Everybody knows somthin.
Nobody knows everything !
Old 05-29-2011, 10:48 AM
The fitting looks like an oil drain back line.
Old 05-29-2011, 12:36 PM
Scott65's Avatar
It is an oil drainback line, haven't had time to plumb it to the pan yet. On the weight, I didn't weigh it, but it was less than half the stocker for sure. Probably less.
Old 05-30-2011, 09:50 AM
I just weighed the 5 core for my 65, 28lbs
Old 05-30-2011, 10:29 AM
Jim Hand Jim Hand is offline
Performance Pontiac Author
Guys,
While the aluminum radiators are usually lighter, they hold more coolant. Thus, the total weight will likely be greater then brass units. I use a large core Griffith and gained close to 15# over a large brass radiator due to the added volume of coolant. But it sure cools better!
Jim Hand
Old 05-30-2011, 08:03 PM
dlw6767's Avatar
ill take the added weight any day for the koolness..
Old 05-30-2011, 10:14 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Does an aluminum radiator with electric fans run cooler than a stock radiator and fan setup?
Old 06-08-2013, 06:21 PM
Tpower66 Tpower66 is offline
I agree with Jim Hand. Griffin's large core radiator cools much better than my Harrison 4-core. Also no problem with the fit on my 66.
Old 06-08-2013, 07:18 PM
mchell's Avatar
mchell mchell is offline
ditto on the Griffin capacity to cool....5 blade clutch fan with the standard duty clutch cools exceptionally....no need for electric fans on mine.......and it gets a little warm down here in the summer!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 06-08-2013, 08:11 PM
Pontirag Pontirag is offline
does the griffin look stock?
Old 06-08-2013, 08:22 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Pontirag, the griffin looks pretty stock. That's what's in my 64. Welds and no Harrison stamp are the big differences.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 06-08-2013, 11:17 PM
rohrt rohrt is offline
Have you seen these?
http://www.championradiators.com/page/450719580
Old 06-09-2013, 08:11 AM
67cruiser 67cruiser is offline
Mind if i ask?? Are your breathers tied into your Valley pan???
Old 06-09-2013, 10:03 AM
carcrazy carcrazy is offline
Originally Posted by rohrt View Post
I have one (but not either of those models) in my 67 GTO. Mine was a little more expensive but less than $300. My motor is a 455 30 over built by CVMS. 629hp. It stays at 180 degrees when idling for 20 minutes at 80 degrees outside. I have factory stock clutch fan and no shroud (yet).
