Head question 1 million...
Do the pushrod holes on Edelbrock aluminum heads need to be enlarged the same as iron heads if I plan to use 1.65 rockers?
as always thanks Steve |
yes
Thanks as always!
Steve |
wth??? You mean Edelbrock didn't know enough to clearance the pushrods? I will believe you just in disbelief on ignorance. Heck even less material on each pour! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
I guess I need to take a close look at my set up. I'm running the HS 1.5 rockers that are supposed to be closer to 1.6 and I don't think mine have been enlarged.....
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers.... |
The E-head is not a copy of the RAIV head although many believe that to be true. The RAIV came with 1.65 rockers from the factory.
Like Ken said, the E-head pushrod holes won't work as-is for 1.65s. |
Just take a look at the pushrod holes on your stock Edelbrock -- Nice small round holes. There's more than enough room to oval shape them, but I was warned to be somewhat conservative because the water jacket is pretty close to the pushrod hole.
So about how much material are we talking? 1/8th inch back towards the spring, or away from the spring? I need to have mine done.
Britt
1975 Firebird / 1970 4" stroke 400, 6.800" Rods, 87cc Edelbrocks, XR-288-HR roller cam, Harland Sharp 1.5 roller rockers, Edelbrocks Pro-Flo4 port fuel EFI, Super T-10, 3.73 Posi. |
Is that the case for just the performer heads? I would think the RPM heads are set up to run 1.65's
Yep, Butler enlarged mine while he was doing the "race port" on a set of RPM heads.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Ok, Checked mine and they are round, anyone wanna loan me or sell me the tool needed to make this cut. I think I some type of drill jig in the back of Jim Hands book but don't know where to get it.
thanks Steve |
