Seems like alot of 73's being restored. GOOD! These 73's are a one-off deal. I am still trying to decide whether to pull the front sheet metal off and remove the front frame. What if I can't get it aligned again? Here are the Pics I promised
![]() This is before I went crazy. ![]() This is after I pulled the engine (71 HO flowed heads, Cliffs carb, HEI, 068 cam, 1.6 roller rockers, and Tri-Y headers) ![]() Do I drop the front frame or not? ![]() Turns out I have to pull the nose off anyway to replace this crappy radiator support grommet. Can I leave the fenders bolted on and still drop the fame?
BrockB 1973 Trans Am |
WOW!
An admiralty Blue 73. Looks pretty good in that color. If the sheet metal lines up OK now,then it will go back that way. Sheet metal alignment problems are almost always a result of poorly repaired previous collision damage. |
if you're doing new bushings (core support, subframe, door hinge rebuild etc.) I'd dismantle the front end because it will definitely go back together differently shim-wise.
I agree with 2manyT/A's, that car looks good in admiralty blue. Are you going to keep it that color?
Don't be worried about removing the subframe. I got mine back in, aligned and torqued up in a little over an hour....by myself, with two floor jacks, a pair of home made 5/8" rigging pins and a tape measure.
Wasn't as hard as you'd think. Get the frame measurements from the workshop manual to help.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
Nice to see another 73 under the knife!
I was hesitant to remove the subframe too, but so glad I did! It does fall under the "might as well" tasks and does add a few more things to do when its out, but in the long run, much better to go all the way.
chuck... 1973 455 TA (07A) |
![]() Quote:
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
![]() Quote:
The body is straight as an arrow. I am calling you if I can't get the panels back on. ![]()
![]() Quote:
![]() Quote:
Color changes were a common thing on these cars back in the day. On the panel alignment,I've seen some shops that will drill 1/8" pilot holes beside critcal body bolts to make sure original panel alignment is retained on re-assembly. It couldn't hurt to take pictures of your door hood & fender gaps & don't forget to tag & bag the shims you remove. It ALL helps when you are putting it back together. |
Wow,I too have never seen a 73 done in Admiral BLue,looks good,but if redoin,I'd go with original BG.
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match 1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match 1999 T/A Navy Blue 60k mi....babied ![]() 1968 442-gone but not forgotten "Oh,you can think about it,.....but don't do it!" Sheriff Bufford T.Justice |
Well as said the gang stated they would go to the orignal color..... I think it looks beautiful in the Blue and unless restoring to factory correct,,, I wouldn't change away from what is obviously a beautiful color on the car.... Heck you've got a rare TA just because of the wrong color,, but it sure looks nice that way....
I've never heard of "brewster red", what is the paint code for that one?
![]() Quote:
Good for you,,,enjoy the car that's why they built them...
Hows this 73 doing??
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
She is getting her engine re-installed. Then we put in the Vintage air, insulate the interior, and install the sound system. Then on with the fenders, nose, exhaust and frame brace.
Update pictures please, Brewster Green is a killer color but the blue looks good too. Bottom line stay within budget and make sure you keep it enjoyable.
Engine is back in the car but I screwed up. I should have taken pictures BEFORE I pulled the engine and accessories. Does anyone have an original 73 engine compartment I could take pictures of?
![]() She barely fits in my garage ![]() This a 1967 cadillac blue. The wheels turned out nice. ![]() Where do all those other parts go? ![]() Don't those RAIII manifolds look nice?
Looking Stellar!!
