Old 10-18-2010, 03:37 PM
DEEZPAZ's Avatar
DEEZPAZ DEEZPAZ is offline
Default Unloading some parts...
OK, I've been collecting some parts for about a year while I do my restoration on my 79 TA but I've come to find out that some parts I don't need as mine are currently repairable and were never needed in the first place. Guess you shouldn't get ahead of yourself and buy things you might not need. Thats what I get for listening to a body shop!! Well my loss is your gain...
There are too many parts here for pix but if you ask I can send you some...
Brake booster - $75 freshly painted, few chips on back
Master cylinder - $50
Repro red nose emblem - $30
OEM RH front grill - $100 very good condition
Repro outside door handles - $20
4 Chrome headlight bezels - $50 slight pitting on bottom of all 4
3 OEM wheel center caps with Pontiac arrow - $60
4 New wheel center caps with Pontiac arrow - $50 I believe these are NOS as they have the sticker on the inside.
Windshield/rear window trim - $125 each but would rather sell them as a set
Rear valance - $25 mild surface rust on the inside
Fiberglass spoiler, front & rear flares (5 piece) - $250 Seen online for $300-400 for set
RH/LH fenders - $500 each RH fender is near mint and LH has some very minor rust. Neither has dents. These are for local pick-up only as they are too large to ship!
Front spoiler - $75 Middle bracket is cracked but held onto radiator support fine and a crack in the center on the bottom which is hardly noticeable.
Front flares pair- $50 LH has small crack near bottom of mounting bracket and bottom mount is cracked but didn't effect application. RH has one bolt on mounting bracket halfway snapped off but no damage to flare.
Turn signal - $20 I believe is pre-79 as it has the hole on the end.
Hood hinges - $50 They opened and closed fine when they were on the car. Will need to be painted.
Shifter knob - I have 2 of these: one is in near mint condition w/ minimal wear and the other has a small crack in the top near the button and 2-3 little indents. Looking for $25 for the near mint condition one and $10 for the other.
Shifter button - I have 2 of these: one is near mint with hardly any wear and no scratches and the other has a small, faint scratch. Both very good condition. Looking for $25 for the near mint condition one and $20 for the other.
Old 10-18-2010, 07:09 PM
DEEZPAZ's Avatar
Correction: the shifter knobs are for an automatic car.
Old 10-18-2010, 08:50 PM
cnc's Avatar
cnc cnc is offline
Interested in the booster...pm sent
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-19-2010, 11:40 PM
DEEZPAZ's Avatar
Outer handles and emblem sold..
Old 10-19-2010, 11:41 PM
DEEZPAZ's Avatar
The shifter buttons are the red bird!
Old 10-20-2010, 12:11 AM
DEEZPAZ's Avatar
Turned up 2 more pieces for sale:
Steering wheel and hub - $50 The wheels foam has cracking either to sun or heat but still feels relatively soft and a small hole in the backside at the 12 position. The hub is attached to the steering wheel and has spots of flaking of the paint.
Repro LH/RH 79-81 front grills - $150 These are new and include the screws to attach to the nose.
Old 10-21-2010, 06:16 PM
DEEZPAZ's Avatar
Repro grills sold
Old 10-23-2010, 09:34 PM
DEEZPAZ's Avatar
Steering wheel sold
Old 10-27-2010, 04:45 PM
DEEZPAZ's Avatar
$10 shifter knob sold
Old 10-27-2010, 04:59 PM
DEEZPAZ's Avatar
Brake Booster - pix 3 and 4 show the chips that are on the backside and won't be seen once installed.
ID:	222500   Click image for larger version
ID:	222501   Click image for larger version
ID:	222502   Click image for larger version
ID:	222503   Click image for larger version
Old 10-27-2010, 05:03 PM
DEEZPAZ's Avatar
Master cylinder - I believe this is for a '80 and up Firebird/TA.
ID:	222505   Click image for larger version
ID:	222506   Click image for larger version
ID:	222507   Click image for larger version
Old 10-27-2010, 05:08 PM
DEEZPAZ's Avatar
OEM RH grille - has one small scuff mark (pix 4) on the upper left hand corner near the turn signal but is hardly noticeable. Tape on the top came off when I removed but tape on the bottom is still attached and unused (see last pix)
ID:	222512   Click image for larger version
ID:	222513   Click image for larger version
ID:	222514   Click image for larger version
ID:	222516   Click image for larger version
Old 10-27-2010, 05:11 PM
DEEZPAZ's Avatar
Turn signal - mint condition. I believe this is for a pre-79 Firebired/TA.
Old 10-27-2010, 05:15 PM
DEEZPAZ's Avatar
Automatic shifter knob - Near mint condition.
ID:	222521   Click image for larger version
ID:	222522   Click image for larger version
Old 10-27-2010, 05:18 PM
DEEZPAZ's Avatar
Red bird shifter button - both buttons are in great condition with one being slightly better. The other button is in great condition as well but has a slight scratch in the middle.
ID:	222524   Click image for larger version
Old 10-27-2010, 05:21 PM
DEEZPAZ's Avatar
Button with slight scratch
ID:	222526   Click image for larger version
Old 10-27-2010, 05:25 PM
DEEZPAZ's Avatar
Fiberglass 5 piece front spoiler and front/rear flares - I believe they used the same ones for the new Bandit... They can be molded directly to the fender and quarters to give a seamless look!
Front flares & welting
ID:	222528   Click image for larger version
ID:	222529   Click image for larger version
Old 10-27-2010, 05:27 PM
DEEZPAZ's Avatar
Rear flares
ID:	222531   Click image for larger version
ID:	222532   Click image for larger version
Old 10-27-2010, 05:29 PM
DEEZPAZ's Avatar
Front spoiler
ID:	222534   Click image for larger version
ID:	222535   Click image for larger version
ID:	222536   Click image for larger version
ID:	222537   Click image for larger version
Old 11-02-2010, 11:24 AM
DEEZPAZ's Avatar
Front spoiler - pix 2 shows the crack on the center bracket that attachs to the radiator support but didn't effect application. Pix 3 shows a crack on the bottom of the spoiler in the center which is hardly noticeablel when on the car. All other holes are in excellent condition!
ID:	223147   Click image for larger version
ID:	223148   Click image for larger version
ID:	223149   Click image for larger version
