Old 10-15-2010, 06:13 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Default 65 B body information
Lower control arm information. Please note that the final solution to the 65 lower control arms was to make the 66-70 arms the replacements for 1965 cars.
ID:	221256   Click image for larger version
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 10-15-2010, 06:16 PM
LASJayhawk's Avatar
Rear control arm information
ID:	221258   Click image for larger version
Old 10-15-2010, 06:18 PM
LASJayhawk's Avatar
steering linkage information
ID:	221260   Click image for larger version
Old 10-15-2010, 06:20 PM
LASJayhawk's Avatar
2 speed wipers that won't shut off
ID:	221262   Click image for larger version
ID:	221263   Click image for larger version
ID:	221264   Click image for larger version
Old 10-15-2010, 06:22 PM
LASJayhawk's Avatar
Oh where or where do my 2+2 pinstripes go. G.T.O's also The 2+2 upper stripe is 3/32" then a 1/8" gap to the bottom stripe 1/16"
ID:	221266   Click image for larger version
ID:	221267   Click image for larger version
Last edited by LASJayhawk; 10-15-2010 at 06:26 PM. Reason: dims didnt show up to well
Old 10-15-2010, 06:58 PM
stevep's Avatar
stevep stevep is offline
That is the 1st time I have ever seen documentation regarding a 2+2 pinstripe. People have been questioning me on this for years!
Thanks for a LOT of good info!!!
Can you fax me these bulletins if I send you my fax #??
Old 10-16-2010, 02:10 PM
2+2+3x2's Avatar
2+2+3x2 2+2+3x2 is offline
Great info Jayhawk, never knew about the rear control arms, I'm about to remove mine to install new bushings, I'll look for those numbers.
Old 10-16-2010, 03:51 PM
65catalina's Avatar
65catalina 65catalina is offline
Awesome information, thanks. I know my front lower control arms did NOT have the reinforcement bracket, but not sure of the rears. Never noticed any numbers on them when they were sandblasted, but didn't know to look either.
71 GTO stroker, with TKX 5 speed
65 Catalina 2DHT, 389 bored 0.060 over, Crower 60916 cam, #16 heads, CR Q-Jet, TH400, Continental 13", 3.42 Posi, Frame-off resto, RARE Long branch manifolds, 2-1/2" Pypes with X-pipe and Goerlich Turbo mufflers
Old 10-17-2010, 05:03 PM
LASJayhawk's Avatar
Wind noise. Part 1 of 3
These should have better resolution than the last ones I posted
ID:	221452   Click image for larger version
Old 10-17-2010, 05:06 PM
LASJayhawk's Avatar
Wind noise Part 2 of 3 . 1 service news flash, but it's 10 pages long
ID:	221454   Click image for larger version
ID:	221455   Click image for larger version
ID:	221456   Click image for larger version
ID:	221457   Click image for larger version
Old 10-17-2010, 05:09 PM
LASJayhawk's Avatar
Wind noise part 3 of 3
ID:	221459   Click image for larger version
ID:	221460   Click image for larger version
ID:	221461   Click image for larger version
ID:	221462   Click image for larger version
Old 10-18-2010, 02:28 AM
Heybuck's Avatar
Heybuck Heybuck is offline
Default "Fix" for rear main oil leaks....
In one of the Service Bulletins, there is a reference to the Dealers about "curing" rear main oil leaks.
I've seen this once before. Maybe you ,Jayhawk has a copy of it??
From memory, it basically says that if a customers car comes in for service and it is demonstrating the rear main is starting to leak, the answer is to remove the cover plate, weld up the drain hole and drill another hole a few inches further up!!!!
That's always amused me. Can you imagine that sort of dealer service bulletin being sent out today??? Not likely.....
Ian
To laugh at men of sense is the privilege of fools.
