Trans ID
I have a Borg Warner Trans. I was told it was a Super T-10. The numbers and letters on the pass side are 304 065 WG Div 10-01-71. WE2062. Does anyone know what these numbers are? I belive WE2062 is as follows: W Warner E Month 20 Day 6 year 2 Shift. Thanks Rich
If everything seems under control,your just not going fast enough. Mario Andretti ________________________________________ May God have mercy upon my enemies, because I Won't. General George Patton |
It's an ST-10.
The date is right. How many grooves on the input shaft? Also above those numbers at the top should be a little 'pad' with a stamped set of numbers,(sometimes) what are they?
Trans ID
Thanks for the info. I don't recall any other numbers. I have to take another look. What determines that it is a ST-10. Thanks Rich
The ST-10 was made in 76.
There should be a 904/903 or something after the 304 065 I believe. This will tell you what the case is made of.
Trans ID
Thanks again. Rich
