PTFB A-Arm Bushings - Repost from Suspension Forum
What does PTFB use for bushings in their comp tubular A-arms? The website shows "bronze thrust washers" and "greaseable solid pivots". I understand the thrust washers but there is no explanation of the what makes up the solid pivots.
I'm thinking they would work well with a set of tall ball joints and my 1LE brakes. Thanx, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi. “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
Not possible.
Call Dave and ask him. Pretty good guy. I can't tell for sure I can take a picture of the ones on my car.
A pic would be great. The ones pictured on the PTFB website don't show the bushings plus they look more like 1st Gen arms but who can tell from a picture. From searching the suspension forum I found a thread started by Z code 400 where Dave rang in about the fit of the arms. Stewart
