'Bored of Work' project: Lexan valve covers (clear)
I think these would be neat
I've been testing valve cover types and thicknesses of lexan, polycarbonate, etc Tons of ways to go about it, but getting close on the first prototype I hope to have it mounted tomorrow The lexan I've got at the moment says it easily withstands temps over 300 degrees Mounted to the aluminum valve cover with a gasket in between, I'm thinking I might get by without it warping? Even if it lasts a year or two and needs replaced: no big deal for how neat they look Anyone else tried it? I heard they sold 'em in the 60's...all Lexan and they warped. Mine isn't all lexan...and the materials are better these days Thoughts? Looks cheesy? I included a google pic of someone else's project I've always thought my HS roller rockers were too pretty to cover up.... And I haven't had time to play with the car much (it's a few states away), so this gives me something to do
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE |
I remember in the mid eighties you could purchase small block chevy clear valve covers. I saw them at a local speed shop here in NE Pennsylvania. Don't remember price or who manufactured them, but thought they were pretty cool.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
Cool concept. Wonder what it's going to look like once the oil is splashing all over them.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
they were made at one time.There is a guy in Harbor City that puts a set on ebay from time to time for stupid money that never sell.Tom
Roland Racing offers modern clear-top rocker covers for the CV-1 heads. I imagine that Jim Sammons would answer any questions you have.
I figure just the window in the top of them will be easy/simple Quote:
I'll try to make mine for substantially less...maybe even make a few different pair and put 'em on here I've got 3 different pair of valve covers here I'm experimenting with, at the moment.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
i'm in total shock that no one is giving you hell over the 'heartbeat' breather! i think those covers look great.
John J. |
The motor those covers are on is a SBC.
I'll probably have holes in each of mine for breathers - last thing I'd add
working on them at the moment...
that would explain it! i didn't even look that close...
John J. |
coool
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
The second hand story on these valve covers, from the guy I got them from, Pontiac built them for display. No way of really knowing, no marking on them from Pontiac or aftermarket co. like Mr. gasket etc. I would fill thru the dipstick tube.
IIRC Performance Automotive Warehouse did sell those, and maybe J.C Whitney as well. You might look online and check speedway too. They have some vintage stuff.
How about not having oil drippers?
Most don't have them anyway?
I don't think I've had them in quite a while I assume you mean the ones on the bottom of stock valve covers? PS. No progress. Not nearly as easy as anticipated MT and Holley alum valve covers have VERY thin walls - almost worthless And one raised part on them that doesn't even make them easy to mill (the different heights make it uneven, and you end up with an uneven hole)
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE Last edited by baron_; 06-21-2010 at 07:38 AM. |
Nothing new, been around many years. I ran these translucent valve covers back in the late 70's and early 80's on my GTO. I also had a clear distributor cap. They were readily available in the aftermarkey world (J.C. Whitney). I think I still have the valve covers up in the Hay barn loft. The valve covers were copmpletely translucent and never warpped or turned yellow, they did tend to crack under the heat however, thus my removing them.
Tim john--- |
I have seen a nice set for Chevy's that have a sealed door so you can easily run the vales without need to scrape gaskets for 20 minutes. Though about adapting a set of doors on mine now that I'm back to the solid roller.
TigerEFI.com (Classic Pontiac Fuel Injection) 2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration. |
