Old 06-04-2010, 10:57 PM
wannabefast's Avatar
wannabefast wannabefast is offline
Default will 65 GTO disk brake spindles work on a 67 firebird?
I have a set for a 65 I might use on my 67 if they will work. Thanks
69 Firebird - 8.54 at 159mph 1.22 60' 2400lb's
Old 06-04-2010, 11:02 PM
The '64 -'72 A-body (GTO) spindles will interchange onto the '67 -'69 F-body (Firebird) cars, just use the steering arms from the Firebird spindles.
Old 06-05-2010, 08:02 PM
That's what I was thinking but my buddy said they wouldn't work. Thanks b-man.
Old 06-06-2010, 08:36 AM
boater bill's Avatar
boater bill boater bill is offline
I've got 69 GTO front spindles and calipers on my car. It's a snap to swap the steering arms. The trick will be if you are going to use the 4 piston calipers from the 65. They are correct also for your 67, but tend to leak fluid around the piston seals. Have the calipers sleeved from someone that does a lot of the Corvette calipers. If you are converting from drum brakes be sure to replace the master cylinder and proportioning valve also.
Good luck.
Old 06-06-2010, 01:28 PM
Good luck.
The disc brake option for the A & F-body cars wasn't available until '67, but great advice nonetheless.
Most disc brake swappers will avoid the '67 -'68 4-piston caliper setups and go for the '69 -'72 single piston units.
