What would a nice, complete and original '67 Firebird Ram Air set-up be worth? Story goes a company official at the Lordstown, Ohio plant was given a RA car to drive for a year and before he turned it in, he swapped the RA pieces for a stock air cleaner. This one has the wire mesh screen and all. Had it media blasted and it has absolutely NO rust issues. I was told that it is a one year only deal, as the '68 unit did not have the provision for the California emission tube in the base. This one does and still has the factory plug in it. Just curious, as so few cars were made. I believe the repops are modeled after the '68 units with no hole. Any info appreciated. Ron
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Lots if you have a car that needs it.
What do you mean when you say wire mesh screen and all? Got a picture?
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
there is a wire mesh "cage" that actually apears to have surrounded the paper element air filter much like the ones seen on Tri-Power units. Probably so a foam pre-wrap could be used. I'll post some pix shortly. You mean you don't have a couple of these lying around?
Like this? Just one.
Ron:
A clean bottom 67 pan is probably not worth much more then a comparable original 68 pan. I have one 67 bottom pan and that is about what I paid for it. Only bought it to get the exact hole dimensions. (I’ve had maybe 2 requests total for a true 67 bottom pan over the years, so I was thinking of creating the 67 hole on maybe a dozen on the next run) The problem with the true 67 bottom pan is that they are only worth a bunch to one of the 65 original cars and I would think less then 10 still exist or someone that really wants a fully correct clone. The 68 guys don’t want them as the tube won’t work and the 67 guys that are just adding RA won’t pay much more for it as they just plug the whole anyway. As far as the screen, I’d like to see a picture also. Are you talking about the hard screen and foam like the Tri-Powers and the Louvered Air Cleaner used. I’ve never seen that used on a RA set-up. (Jim M. probably knows were all of the originals are so he may be worth contacting) |
here are some pix. Similar to the Tri-Power screens that use the foam pre-wrap. Are these referred to as "flame arrestors" or what? I believe this is @ 14" diameter. Fits the R/A lid anyway. We also now have a "correct" XN" coded block and may possibly be forced to sell off this project, but I will post it here first if/when that decision is made. Thanks for any help, Brian. It intrigues me that you have never seen one of these screens. As I said...It's from factory official's car at the Lordstown plant so I'm relatively certain that it all goes together. Let me know if any of you could lend some insight. This F-body stuff is all new to me. Thanks again. Ron BTW...talked to JM but mostly about the block. Didn't discuss configuration of the R/A set-up, although I probably chould have asked.
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. Last edited by Ron Landis-formerly Jegstek; 05-27-2010 at 12:54 PM. |
Ron, I've never seen one of those either - for that matter the one NOS in-the-box setup I saw years ago didn't have one.
Very cool - might be a part from engineering. (Saw your old Red/Red 69 cruising through town here the other day - looked sweet!)
On page 341 of the GTO Restoration Guide there is a pic of the foam heavy duty air filter that this screen was used in for support.
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
Ron:
When it comes to the 67 RA FBs, I have more questions then I have answers. There is not much info out there on them. As in the case of the system, the 68 GTO/FB systems were prepped and hood cut by the dealer – the std. air cleaner was on the car when it arrived at the dealer. If the person you know had a 67 RA directly from the factory – who prepped the hood? As far as the screen, the 67 GTO and FB 400 had the HD air cleaner available. They both used the same screen and polyurethane element. I have just never heard or seen evidence that the 67 RA cars came with anything but a paper element. Do you know the person who had the 67 FB? Is it possible the car had the HD air cleaner on it when the RA system was installed and the screen was left from that? Does it look used? If you do know him - does he have any pictures or documentation that he would share? (I would even be interested in just stories!) ![]() Brian Last edited by brians; 05-28-2010 at 10:17 PM. |
![]() Quote:
You may be onto something with that screen and the 65 GTO.
Ive got one thats part of the 66 Sprint louvered air cleaner. Never seen one on a Bird or GTO RA setup
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
![]() Quote:
answer to my initial inquiry would be; "Who knows!"? lol This IS interesting...don't get me wrong!
i agree you never know. i assume dealers would have installed it if it were not a special order car. who knows. all i can go on is the account of this guy who was very very knowledgable in the car and when i bought it, it really wasnt all that old. this guy also never painted the open scoops. he said he installed them black and that is the way they are today.
And the story is still going around of the removal of the RA components
that were in the trunk,by well meaning security guards, thinking they were items being smuggled out. Getting back to the screen... if you had the HD foam filter you had a screen to hold the foam in place. Paper filters didnt need a screen.
![]() Quote:
Ron:
Was doing a little digging on this and everything I can come up with points to that screen was not part of the RA system in 67. The 68 parts book shows all the screen and foam numbers for 67, however only the paper element is listed for the 67 FB with RA. The 67 FB supplement service manual states that the heavy duty Polyurethane filter is available on all engines except Ram Air. I looked at copies of a 67 RA FB and RA GTO road tests. The engine pictures are B&W and grainy, but the air cleaner element looks very light. The foam element should appear dark. If you get a chance, would you post a picture of the bottom of the bottom pan? Brian |
as soon as I get over to the shop I'll snap a few pix. Just odd how this thing fits perfectly! Also that it is so similar in configuration to the Tri-Power style set-up it replaced. I would have guessed more likely to be screen/foam in '67 and maybe paper in '68 or later. Nobody said it had to make sense, though...right?
none of the ram air components were installed on the 1968 gto from the factory. i was at the dealer when my 1968 ra1 arrived. everything was in the trunk. a regular air cleaner was on the car. muscle car if your friend said his car had the base pan on the car the dealer put it on. at the time i worked at the dealer and i do still have the car. we sold 2 other 68 gto ra cars that i remember. i don't remember selling any ra firebirds....jerry
![]() Quote:
