Old 05-18-2010, 02:32 PM
wilma wilma is offline
Default Which brake shoe goes where?
Long story short, for a variety of reasons I had my local wrench put on a new set of front brake shoes on my 1968 GTO while he was doing other front end work that I don't have the tools or the time to do. I didn't tell him to turn the drums so of course he didn't and of course I realized they needed turning when I got the car back and drove it a bit. Since I had a few hours today I pulled the drums off and had them turned, but I noticed that he put the brake shoe with the large asbestos pad on the back of the plate facing the rear of the car, and the shoe with the smaller asbestos pad facing the front of the car. It's been a long time (30+ years) since I did drum brakes, but intuitively this doesn't seem correct to me. Can anyone tell me if in fact this is the proper way to install the front brake shoes? I'd like to have an expert opinion before I take it back to him. FYI, with the turned drums on it the car stops fine now.
Thanks!
Old 05-18-2010, 02:50 PM
Old Goat 67's Avatar
CORRECT. Large shoe goes to rear of car, because it is the first to make contact with the drum as you apply the brakes in the forward motion of the car therefore having the most wear of the two shoes.
Charles
Old 05-19-2010, 07:05 AM
Default Thanks
Old Goat, (I can relate to that...) thanks for your reply. I'll enjoy my newly found stopping power worry-free.
Old 05-29-2010, 09:31 AM
Bandit400 Bandit400 is offline
Sounds nasty but and old shop teacher told us to think of prison when working on drum brakes- the shoe that is longer, harder and darker goes in the rear. :-0
Old 05-29-2010, 10:23 AM
Old 05-29-2010, 06:28 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Ouch!
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 05-29-2010, 06:49 PM
guccieng's Avatar
guccieng guccieng is offline
bad visual, bad visual *repeats to self in futile attempt to erase memory*.
John J.
Old 05-30-2010, 12:02 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Charles
Actually, the reason is that with the rotation of the drum, the front shoe grabs and the whole assembly is rotated slightly, jamming the large shoe in harder. There's a name for this, but it's escaping me right now. Guess I better brush up before I take my brake test again..
FWIW, the rear shoe does all the work.
Old 06-01-2010, 11:08 PM
59safaricat 59safaricat is offline
Just remember this applies to Bendix style brake systems. The leading/trailing design (pretty much used in most applications today) is the opposite.....bigger shoe goes up front.
Old 06-02-2010, 10:31 AM
chipster's Avatar
chipster chipster is offline
The name is "Self Energizing".
Old 05-21-2015, 07:09 PM
Terry M. Hunt Terry M. Hunt is offline
So what happens if you get this backwards? What symptoms would you expect to notice when braking?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 05-26-2015, 01:35 AM
Schurkey Schurkey is offline
Primary shoe mis-installed in the secondary position? Excess wear of the short, soft, white shoe. I don't remember what the braking performance is like--perhaps grabby brakes.
Old 05-27-2018, 02:40 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
landed on this old thread doing a quick search as I was trying to remember shoe direction.
Decided to grab the 68 service manual to confirm & Interestingly it shows the longer primary shoe towards the front of the car. Hmmmm
Seems odd, Different type of shoe though looking at the picture.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 05-27-2018, 03:32 PM
From 67 Shop manual, Page 5-9;
NOTE: When replacing shoes, always be certain
to assemble secondary shoes to the rear and pri-
mary shoes to the front. Note that linings of pri-
mary shoes are usually shorter than secondary
linings.
Old 05-27-2018, 04:31 PM
First Guess: Somebody screwed up when posing the parts for the photo.
The secondary shoe would get the park brake lever, and be towards the rear. However, I'd expect it to have the longer, thinner, harder darker-colored lining material. The primary would get the shorter, thicker, softer, lighter-colored lining material.
Old 05-27-2018, 08:47 PM
LATECH's Avatar
LATECH LATECH is offline
Yep. X2 with shurkey
The primary shoe is the shorter length of friction material
The secondary is the longer length of friction material
Also, the "Strut " they have pictured is what I refer to as the "reaction rod" for the parking brake.
Old 05-28-2018, 06:23 AM
68ragtop's Avatar
Intersting picture for sure. Makes me wonder how many got installed backwards because of this picture. Mine almost did.
Also, I noticed they have the strut shown backwards as well. No way its installing in that direction.
89 Trans am GTA
