Anyone have one of the after market LED tail light kits on their car?? I'm curious how you like it and which one you installed ??? Specifically a 67/8 version.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
I ve got some in the works
But they have been on the work bench for over a year also. Im just using the lens and LEDs and making a new reflector.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
I installed leds on mine last year and I love them. Takes about three hours to install. If your handy its not hard. I got them from www.spaghettiengineering.com . go to the web site and it will show you how they will work its cool. Good luck
http://firstgenfirebird.org/show/closeup.mv?CarID=326 |
pricey arent they
I've seen them on a local car. He had them setup for sequential mode (you can run them in normal mode as well). Even on a nice sunny day, they definitely grab your attention far better than the stock setup.
Not only that, but LEDs in general will come on faster than conventional taillights. On European cars, many started out with LED 3rd brake lights and conventional tails, and you could see the 3rd light respond first (it's quick, but visible to the human eye). That could mean a few extra feet of response time to the driver behind you (which can be the difference of getting rearended or not). So its more than just a cosmetic thing, it can help for safety as well. I plan to get them.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
those are the best, not cheap, and still a year away from me putting on the camaro. i think the fast on/off of led's benefits in the 'attention getting' category, as it's not usual in nature to see lights come on and go off that fast.
LED bulbs are sold at electrical stores, both single and dual element to replace the stock bulbs, but, unless you want your tail lights to look pink, you need to get the red bulbs. I replaced mine several years ago and have yet to use any of the spares that I bought. They're not cheap, but they last a long time.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 ![]() |
