BEST CLUTCH ASSEMBLY FOR MY 66 TRI POWER
Finaly getting around to installing my rebuilt tripower engine in my gto but need a new clutch assembly. With all the new clutches out I need some suggestions. Any help is appreciated. Just going to be a weekend driver and smoking the tires often.
I have had good luck with CenterForce clutches.
The light pedal is really appreciated. |
Ram HD series. -Jim
I have successfully used both the Center Force Dual Friction and McLeod clutches.
i went from a CFII to a ram progrip, on my slightly modified '64, and like it much. it's a little harder peddle, but i like the way it locks up sooner than the CF.
You may like that hard engagement but your driveline doesnt.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
sorry it's not a progrip its a powergrip clutch i am running. i am sure it will work fine for most stock to modified applications. been running mine for over a year now no problems.
I ran both of mine hard on the street, and occasionally at the track. The car was running 10.80 at about 130, so the clutch took some abuse.
I run a RAM as well with no issues to complain about. I experienced a little clutch chatter at the beginning but no longer. A Center Force Dual Friction is also very popular.
Tim john--- |
