Rear grear ?'s
I have a M22 with a 3:55 posi. Just thinking about going to a higher ratio for better gas mileage, & to lower the work load on the engine (rpm wise).
Still want to be able to break the tires loose once & a while though. Any good suggestions? |
323s would make so little difference it wouldnt be worth it 308 on a percentage basis wouldnt get you much. Taller tires if you can can get you the same for a lot less buck and work.
Or a T56 tranny (6-speed)... got a buddy who gets 26mpg or little better in a Camaro with a 383 & 4.11's....
1972 LeMans Luxury |
I would agree with Logun1970 if you have the budget.
I have the stock 278 gears in by non-posi with a stock 350 automatic and I can smoke my tire. Highway gears will never stop a manual tranny from raping your radials! |
Just put a new set of tires on the rear, but love the idea of that Muncie overdrive. Oh no No more rock crusher 1st gear pitch????? Don't think I can live without it
The muncie OD is a 3 speed with 4th being an OD gear.
JLP |
