Best Aluminum rad?
468 on my '68 'bird. It runs right around 190 in the summer while moving. On occassion, when in stop and go traffic, in 90 degree weather, she'll approach 120+... then I shut her down.
I've done all the usual water pump, upper rad hose, a/c baffle stuff. I have a 19" clutch fan I am going to try but, I'm thinkn' the 4 core brass/copper rad(fresh re core) just can't cool this larger engine. Whats the best aluminum rad out there? |
Maybe a tad pricey today but i am very pleased with the Rodney Red.
Scott If you always do what you always did You always get what you always got |
I have a Be Cool.
Dropped my running temps by 20+ degrees. |
if you want factory stock looks in aluminum:
http://www.alumitechreproductions.com/44.html?sm=2764 (just put "Firebird" in the search box at top, the discount requires it be bought online) Here is a post on how to save $100 during the month of December on Alumitech radiators, they have to be $495 in price or higher but that should apply to the Firebird radiator as it's priced at $495, the discount code is tcxmass: http://www.chevelles.com/forums/show....php?p=2655638 .
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe Last edited by RicksGTO; 12-13-2009 at 10:58 AM. |
rodney red is the bisenis. my 193mph Pro-Touring G-mashine street roadracer never ever runs hot!!! i use there underdrive pullys as wel...............
I purchased one from our sponsors (PY) and it fit good in my 75 TA. It also solved my cooling problem on my 505 CI motor with stock fan.
Be Cool makes great stuff. They are all-welded construction. Some others are glued together and if they spring a leak, you have to throw them away.
If the car cools good enough while moving, your radiator may be fine. If it overheats (only) in stop & go or slow speed, that's usually a sign that your fan isn't moving enough air. You didn't say what kind of fan you have now. A factory clutch fan pulls more air than a flex fan. Adding an auxiliary electric fan is another option. Hope this helps, Eric |
Check out Allstar Performance Triple pass Alum. radiators. been using one for the past 4 years. awsome product for half the price. Side by side looks like the high priced brand.
Alumiteh for that stock look. I had Don build me a couple custom radiators for my 61 and 63 tempest. They made a big difference and were worth the money and peace of mind.
I've got a rodney red, a be cool and a $120 summit aluminum.
Honestly, I've no complaints with any of them...and would probably go for the cheapie next time
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE |
I use Griffin radiators in both my 69 GTO and 72 Formula and they have been great too.
When you changed your pump did you look at the seals between the pump and timing cover? And the divider plates?? These can corrode and leak causeing bad water flow in the system. And are cheaper than a new rad if they are the culprit.
JUst my .02
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
I have a Griffin radiator. NO complaints other that the lower hose is on an angle pointing towards the engine and up. Took me awhile and with some help from other PY members got the correct hose.
I have the MARK VIII fan. Slow speed on a temp sensor in the intake. comes on at 190*-ish, High speed is on a toggle switch. Honestly, I had the car out yesterday in 25* weather, the car ran too cold. Would not come up to temp unless I was beating on her up hill.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
Tell me you DON'T actually have your radiator mounted with tie straps....?? |
(long morning) It's now stinging my nose. Good call.
No!!!! Those where there to hold it when I was making the brackets. I needed it as tight as possible so I could measure.
Yeah.
WWW.Mark7radiators.com is whom I would reccomend for the very best in performance and quality in an aluminum radiator. They also offer them in an anodized finish for maintance free appearance in a rainbow of colors. These WILL outperform any Be Cool, Rodney Red, Griffin, Alumatech, etc... The Mark 7's have two 1 14/ tubes in the core and the others very best units only have two 1" tubes. You certainly get what you pay for in a Mark 7.
Tim john--- |
1967tempest
I also have a radiator that has the lower connection pointing up. What is the part number for the correct hose and where did you get it? Thanks Karguy |
You can get a Griffin for under $180 if you shop around.
Tempest455 |
lower hose
1969 Chevrolet Pick- up C10 307 Engine with A/C. Turn it upside down, and trim to fit. It is like it was made for this application. I'm not sure either of these links will work, because I had to put my zip code in. Dave http://www.autozone.com/autozone/cat...questid=365282 http://www.napaonline.com/Search/Det...+50014+2014024 HTH, Dave
