Horsepower Suggestions for a Driver
New to this site and have spent hours over the last few nights reading and I'm starting to go cross-eyed. I'm addicted!
I have a 68 GTO with a stock 400 and want to get some more power out of it. This is my weekend driver and not looking to get carried away...but it will probably happen. I have read good and bad on everything here. Carb? (Currently QJet) Intake? Distributor? First step is exhaust for me. Thinking of going with the Ram Air Restorations manifolds and 2.5" exhaust. I want to keep it looking as stock as I can. Trying to get as much HP at minimal $$$...but who isn't! Any thoughts? |
first off, welcome to the site!
if it's a street car, you should looking for torque, not horsepower, imho. horsepower numbers get big in the higher rpm ranges. street cars are almost never in those high rpm ranges. if you make the torque, the horsepower will come. also, keep in mind the car is a combination of things. simply increasing horsepower won't necessarily make things better. you have to take into account what type trans, converter in an automatic, rear gear, tire height, cruise rpm, etc. as for the things you listed: carb-working correctly, no hidden hp here. intake-stock iron intakes are best for a street car. distributor-working correctly and advance tuned to motor, some hidden torque. exhaust-matched to engine combo, some hp and torque to be gained, but will required carb tuning. remember, if you change one thing, you have to change everything! tell us what your combo is first and i'm sure you'll get some great info when it comes to 'bang for your buck'.
John J. |
Go with a Pypes 2 1/2" mandrel bent system. A car has to breath to make power.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
If you are stepping up to the far better flowing RA manifolds you need to go to richer secondary metering rods for the carb other wise you will not get the full bang for your exhaust buck plus you may be lean enought at 3/4 to full throttle to detonate, run hot or both!
[QUOTE=CLB1098;3824823]
I have a 68 GTO with a stock 400 and want to get some more power out of it. This is my weekend driver and not looking to get carried away...but it will probably happen. Too Late! As you are a pontiac owner!... I would look at getting dist set up right and carb,Lots of hidden power right there usually and yes a good 2 1/2 X system would be very nice also.. What gears are u currently running? Welcome aboard!
Automatic or manual transmission? Rear gear?
One of the new generation RAIII size cams (I like a hyd roller...EVERYBODY has an opinion what's best), a good qjet on a factory intake, RA exhaust manifolds into a 2.5" mandrel exhaust system and a well tuned distributor.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Look, lets get something straight. As I was told by an auto engineer "all engines produce torque". In fact a dyno measures torque and multiplies it by the rpm and divides it by 5250. The question should be: where do you want the max torque to be? At low, med range or higher rpm. After you have that figured out, then plan your engine combo. Torque is a twisting force.(force=push or pull) (work=push or pull x distance)and hp is work / time. In other words how fast a car of a given weight traverse a 1/4 mile in a quickest time needs hp. Getting the car to move from a stand still requires torque.
Besides this being inappropriate, "build a torque monster" is terrible advice for a fast car - ESPECIALLY on the street where traction is limited. I'd much rather have 350 lb/ft@6000 than 500@3000. This article is still a great way to read about "torque vs horsepower" as they are one and the same. http://www.vettenet.org/torquehp.html Alright... first and foremost. Whats your budget? Your mechanical ability? Performance goals?
'73 Formula 400 Cammed LS1/T56/3.73's 12.92@106.04 2.03 60 ft. <~~ Bone stock LS1 with 4L60E/3.08's Went 12's in pure daily driver trim! A/C, leather power seats, power steering, full stereo, sound deadening, power windows, full suspension, true street tires, power 4 wheel discs, and 25MPG! |
I always tried to explain it like- torque gets the car going and then horsepower pulls it from there, at what intervals those things happen is how you plan your build/tune.
79 Pontiac Trans Am |
Welcome to the world of Pontiac, and to the forums.
Lots of good advice to be had on the forums; but to sift through it all, you need to do some homework (maybe just in your head) and determine goals. Some things to consider when you consider your modifications: Generally, one modification requires at least 6 more to work properly. Do you want to use pump fuel, or do you wish to mix race fuel and pump fuel? Do you have any constraints required by either local regulations (eg. noise) or insurance regulations? Anyone besides you that will be driving the car? Do they have special needs (eg auto trans)? As virtually ALL of us have found, very easy to spend money, and then spend more because we didn't think of everything ahead of time. Again, welcome, and feel free to ask questions. Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
This debate could be solved pretty easily if everyone was required to take a good calculus-based physics course or two.
Absent any other considerations (streetability, etc.), take the car with more horsepower over the range of RPM you need to operate in - NOT the car with more torque. It's math, it's physics, you can't get away from it. As a matter of practicality, muscle cars in general and Pontiacs more specifically tend to produce enough low-RPM horsepower to get the job done without spinning at such high rpm. As a consequence, such engines have higher torque figures than engines of similar horsepower operating at higher RPM. Make no mistake, however. It is horsepower that is getting the job done, NOT torque. How fast would you go with 500 ft. lbs. of torque at 1 RPM? How fast would you go with 250 ft. lbs. of torque spinning at 10k RPM? Put some steep gears in the car w/250 ft. lbs. and it will FLY. You're not getting anywhere in that dog running 1 RPM. Power gets the job done. It's physics - you can't change it. Off the soapbox. |
Torque is physics. HP is just math.
No idea what you mean by that.
Gentlemen (and ladies, if present):
The torque vs horsepower issue has been argued to death. For those who have not had any high school physics: torque is a measurable amount of work and has a defination. Once one has MEASURED torque, horsepower may be DERIVED from torque by a mathematical formula. Thus JohnTN is quite correct that torque is physics, and HP is just math. However, the renewal of this discussion probably does not help the original poster of this thread. Jon.
I agree the discussion gets old, but the real problem is that some folks perpetuate these notions that ignore basic science. There is a mathematically precise way of discussing these things and some here are way off base. Question for you Jon - can you not "derive" torque by multiplying the applied force times the length of the torque arm? Why, then, could we not say: "Once one has MEASURED force, torque may be DERIVED from force by a mathematical formula." Point being, you can't just measure torque to derive HP. You must also MEASURE rpm. Another question - which is faster, a car making 500 ft. lbs of torque at 3000 rpm, or the same car making the same torque at 6k rpm? Hint: think PHYSICS. Last edited by i82much; 11-19-2009 at 11:53 AM. |
"Stick with carburetors or take a class."
What a jackass. U82much all right...you're obviously full of yourself. |
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers. |
My apologies, that was too harsh. I maintain that there are some really fundamental misconceptions about these things and I do get tired of seeing them perpetuated. And I do think anyone who is going to offer their opinion has a responsibility to understand the topic before stating things that are simply incorrect. None of that is a good excuse for being a jerk, and I apologize. |
His goals are stated
