Rear window removal
I have only removed one window in my time and that was a windshield. Will the piano wire work on the rear window as well with 2 people ?? Is there any other way ???
A wire will cut the back glass out,but you might check your local auto parts store for a "draw knife" style cut-out tool.
Works real slick on back glasses & you can do it by yourself. |
Weed wacker string
I just cut one out of a 79 this past weekend. Poke a hole in the corner somewhere and feed the green plastic string through. Works like piano wire but does not harm the glass. It mught break a few times pulling on it but it works great. Do not see saw too much or it heats up and stretches. Just pull and draw at the same time. Works best with two people. I hate using piano wire cause it damages the glass. Also a draw knife works but if you want to reuse the glass, you have a better chance of breaking it with the draw knife.
Good luck. Be patient, I took out three windows this way.
Crusin in the Great White North! |
Thanks, I will give it a try !!
