Old 10-07-2009, 08:02 AM
andermark andermark is offline
Default 1963 bellhousing
I am looking for a 1963 fullsize bellhousing manual shift for my 4 speed conversion, can anyone help?
Old 10-08-2009, 01:03 PM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
Watch ebay. I think they're the same from 61-63 and maybe 64.
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 10-08-2009, 02:28 PM
tom s tom s is offline
63-64 the same and 61-62 can be made to work.Think there is one on ebay now.Tom
Old 10-08-2009, 04:43 PM
Thanks Tom
Robert Lewis
Old 01-02-2010, 11:45 AM
unclescratch's Avatar
unclescratch unclescratch is offline
Wink bellhousing
I have an older cast iron bellhousing for a bellhousing mounted starter. Pontiac for sure. Don't know how to I.D. the year. Have no plans for it if you still need one. Also some flywheel/flexplate stuff. djtech65@hotmail.com
Old 01-02-2010, 05:33 PM
How much do you want for it?
Robert Lewis
Old 01-13-2010, 09:47 AM
Hooter's Avatar
Hooter Hooter is offline
I just acquired a '63 bellhousing. Still needing one? This one is in good shape other than the corner at the bottom where the dust cover goes on has been chipped off.
67 Bonneville ragtop
Old 01-13-2010, 10:31 AM
stevep's Avatar
stevep stevep is offline
The difference between 63 and 64 bellhousings are that 63 uses 7/16" bolts while 64's use 3/8" bolts so the 64 has smaller bolt holes.
Old 01-19-2010, 11:40 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Pretty sure I still have complete changeover. Bellhousing, flywheel, linkage, pedels for 63-4 in storage.
Try calling CRUSHPROOF! 512-386-9889
Old 02-14-2010, 10:29 AM
dr4cycle dr4cycle is offline
Old 02-15-2010, 09:40 AM
chrisp chrisp is offline
Have a good used one from a 64 GTO .
Old 02-15-2010, 10:11 AM
64 GTO wont work for a 63 or 64 big car.Tom
Old 02-15-2010, 01:14 PM
SteveP, the bolt holes are for where the tranny mounts to the bellhousing?
Just 4 bolt holes?
Old 02-16-2010, 10:32 PM
hellerods's Avatar
hellerods hellerods is offline
Anybody have a correct part # or picture?? I have a couple of alum. bell housings with the trans mounting bolt holes clocked clockwise about one or two inches . They are up in the atttic and will get the part #'s if needed. With these bellhousings, you will need a shifter handle offset with a bend to compensate for the trans leaning a little clockwise. Sorry for my pi** poor explaination of said bellhousings All the other GM bellhousings I have ever used had the trans lined straight up in the 12:00 positiion, these two Pontiac are different, the trans bolts up clocked a little clockwise??
Old 02-16-2010, 10:46 PM
Hooter's Avatar
Here's what they look like. Cast iron.
ID:	197542   Click image for larger version
Old 02-16-2010, 11:26 PM
only alu bellhousing I have seen clocked to the side was a Ansen or RC aftermarket bell.Tom
Old 02-16-2010, 11:55 PM
hellerods's Avatar
Default ID bellhousings
What the heck are these, then?? part #9783581-- can you guys ID these bellhousings and what they fit??
Name:	pont bellhousings 001.jpg
ID:	197555   Click image for larger version
Name:	pont bellhousings 002.jpg
Old 02-17-2010, 12:43 AM
late block mounted starter bells with both trans paterns.I belive a ford mounting pattern.I have one of those around somewhere myself.Tom
Old 02-17-2010, 01:32 AM
hellerods's Avatar
Default Ford ???
Hey Tom, Do you mean that I can mount a Ford trans to my Pontiac bellhousing?? If so, I can install a??? I'm not sure I want to know lol How about a strong top loader FOMOCO???
Old 02-17-2010, 11:35 AM
I think the pontiac 3 speed was based on the ford top loader,never had one.I did have a 68 Cat new that was a 3 on the tree full syncro trans.Tom
