Old 07-19-2009, 01:03 PM
gotsnappy gotsnappy is offline
Default 70-81 firebird TA parts, moslty 78-81 also camaro 67-89
I live in college station texas 77845
Some pictures can be seen here:
http://s643.photobucket.com/albums/uu156/gotsnappy/
NEW REPRODUCTION PARTS 67-69
window cranks black knob or white 67-81 10.00 each
Stainless steel front end bolt kit 100.00 (retail 150.00)
1967 - 69 Camaro Parts Used
69 Camaro front sheet metal 400.00 for everything or
fenders 150.00 each
fender extensions 20.00 each
header panel 60.00
lower valance 50.00
69 RS Fender brackets ORIGINAL 25.00 for both
69 RS outer door cover and backing plate 25.00 for both
68-69 RS vacuum actuators 10.00 each ( surface rust and need new boots)
69 RS rear back up lights
67 RS head light buckets assembly 120.00 each
67 RS Headlight door hinge & bracket (2 parts) Orginal w/stickers still on it LH 30.00
67 RS output arm 5.00
One lower control arm 35.00
MULTILEAF SPRINGS 30.00 single
Front springs 5.00 Each SBC
67 68 69 Center steering link 20.00
LAMPS LENES BULB HOUSINGS ETC
69 tail lights lens and housing complete set 60.00
69 tail light housing passenger side 18.00
67 front turn signal lens only 2.00 each
67 tail light bezel with bulb bracket 20.00 each
68 tail light bezel with bulb bracket 15.00 each
68 side markers (turn signals) 3.00 each
69 side markers and bezels 25.00 for the set
69 Camaro headlight bucket and bracket, spring adjustment screws 35.00
67-69 e brake cable( from the parking brake pedal)
67-69 E brake cables rear mounts to drums
69 master cylinder and metering device
Heater core 4.00
Alternator Date coded 9L21 dec. 21 1969
AC DELCO STARTER OUT OF 69 no numbers
67-68 69 interior parts
67 DELUXE door handle 4.00 one only
67 Standard door handles 2.00 each
68-69 standard door handles 5.00 each
window crank handle clear knobs used 2.00 New ones with black or white knobs 10.00 each
67 68 radio face plate cover 3.00
67-68 AM /FM radio station plate 10.00
seat belt headliner Chrome clips
seat belt bolts 5.00
67-68 turn signal wiring harness that goes in the steering column 20.00
67-69 Seat belts on retractor without boot
wiper switch 10.00 67-68 69
wiper nut 5.00
wiper bezel 5.00
lighter housing and bezel 10.00
flasher knob 5.00
69 camaro ash tray door and ashtray
67 or 68 A pillar cover 10.00
Wire gutter covers on side
spark plug wire holders
motor engine lift brackets
69-72 Camaro SS emblem for fender( one side only) in Great shape GM 10.00
69 quarter louver, gills 10.00 one side only
front windshield stainless trim
Driver door glass for 68-69 ASTRO VENTILATION 80.00
door lock cylinders (2) , no keys $8.00
67-69 window guts cranks slides etc
70-73 Camaro parts Will cut up ,parts no title or tags
wiring
A/C controller and lower dash part 40.00
rear glass 100.00
e brake 20.00
door hinges
trunk lid 40.00 good on top, but has some rust on bottom side, has spoiler holes
t tops 85.00
Standard hood 25.00
Wiper motor
and other parts that interchange from 78 – 81
package tray wire boot
rockers
some of the floor pans
trans tunnel
seat mounts
wheel wells
fuel tank straps
subframe
rear 10 bolt axle
79 camaro no motor no trans no axle housing with title 500.00
70-81 Camaro parts (mostly 78 79 80 81)
Light blue horn button cover 10.00
clutch and pedal for manual trans 40.00
console cover/armrest 10.00 tan and black
Standard hood 20.00
70-81 doors with glass 100.00
78-81 rear bumper with metal and cushion 100.00 (no rips)
Driver inner fender 45.00
lower fender extensions
door hinges 10.00 each
windshield with antenna 85.00
jack support bolt and clip 20.00
wire harness for engine
under dash A/C parts
Rear shocks like new only 2k miles on them, rear only 15.00
gas tank with sender 20.00 with dent
good clean gas tank and sender 45.00 78-81 maybe other years
trunk springs 25.00
dome light cover
dome light housing
plastic cowl cover ( part that covers the wiper linkage)20.00
trim under steerig wheel
A/C controler, will need face plate sticker
A/C vents
78 hood release, will need new cable casing
drive shaft 50.00
Ashtray 10.00
Glove box door 5.00
Glove box inside with clamp 5.00
Side marker lights
Toe kick plate 10.00
Speedo cable upper
Steering column
Steering column brackets
Inner bumper front, upper and lower, metal and foam
Core support, has a rust spot by battery but can be fixed easy30.00
70-81 Rally rims set of 4 $50.00 (not 60s style rally rims on Camaro)
81 z-28 parts car
79 camaro parts car with title
Center console 15.00 black auto couple of cig burns and rip where it mounts under the dash , good for driver.
Auto shifter 20.00
dash cluster with lights and hard to find 130 Speedo 75.00
Z-28 gauge cluster 78-81 maybe other models, out of 81 100.00
interior panels
Interior rear quarter ARMRESTS 35.00 EACH
Passenger side front spoiler /ground effect z-28 30.00
Chevy bowtie center cap 5.00
80-81Front grill emblem blue 10.00
Rear view mirror great shape 20.00
78-81 vacuum canister 10.00
tail lights with normal spider crack 40.00 each
core supports front inner bumper
rear exterior & inner bumpers
hood springs & hinge 40.00 pair
fender wells
Windshield wiper motor 10.00
All glass
Radiator 40.00 in good working order, I replaced this one to put in an aluminum one.
All A/C parts
Third generation seats, 20.00 for both
78 Camaro type LT This car am cutting up, good trans tunnel, part of roof, firewall, frame rails, driver quarter, door shells fender extenision and fenders
TRANS AM FIREBIRD Cars & PARTS
81 Trans AM / Firebird roller 800.00 with title
8o Trans am parts car being cut up
Front NOSE in Great shape
turbo hood 50.00
dome light cover
dome light housing
door hinges 10.00 eaCH
Guage cluster with tach, 80 and 81 80.00
steering wheel and horn covers
Rear 3 piece spoiler
Lower front spoilers / ground effects
Rear wheel well spoilers
Radio knobs and a couple of others
Lighter
Gauge cluster
Side markers
Radiator
Radiator shroud 2 piece
Seats
Bumpers front and rear
Front windshield with antenna
All glass, rear with and without defrost
Subframe
trunk lid 20.00 good on top, but has some rust on bottom side, has spoiler holes
t tops Fisher and Hurst 80.00 per set
All A/C parts, GM compressor
70-73 trans am rear window glass 100.00
77 trans am parts maybe other years
Gas tank, straps and cap
Seat belts
Horns
Front fender marker lights
Hood hinges
door hinges
door shells
wiper arm, motor, and linkage
side mirrors
fuel and volt guage
glove box inner and outer door
a/c vents
power window wiring
tail light wiring, fuse box and engine bay wiring
passenger door handle
hurst t top bag
fisher t tops
master cylinder and booster
rear sway bar
rear leaf springs
auto shift plate
windshield trim
manual shifter knob
78 & 77 trans am being cut up into pieces quarter on drivers side roof panel frame rails, etc etc
1955-57 Chevy two door parts
Radio-- not working
Glove box lock with new key. 10.00
Fuel tank strap
hood Chevrolet emblem
OTHER CARS
95 Explorer radio factory 10.00
60s falcon radio 8.00
2001 CHEV. SILVERADO LF. TAIL LIGHT GM# 16524515 & 16524516 one side has small crack not chip 20.00 for set
HUPCAP hub caps hubcaps 5.00 each, thunderbird( t-bird ) cutlass Cadillac Chevy ford, etc
Truck rear glass, I think Chevy 10.00
Spare tires, donuts also other truck rims 5.00 each
70-73 Nova Parts
Wiring harness out of 73 40.00
Wiper washer bottle 3.00
Control arms A arms
A/C Vents & ducts
Door handles
Window cranks NEW and Used
ENGINE PARTS Performance parts, HOT ROD ETC
SBC HEI distributor with coil 35.00
Oil pressure and temp gauges
NEW SUPERIOR suspension Part # 13-1042
3”Lift/Lowering Kits and
Universal/Lift Lowering Blocks 20.00 per kit
Valve cover gaskets new 2.00]
350 TH Transmission
350 TH pan gasket NEW 2.00
Olds 400 300.00
MANY OTHER PARTS
ALL PARTS SOLD AS IS PLEASE ASK QUESTIONS OR FOR PICs, ETC
Call Rusty 979-777-4067 or email gotsnappy@yahoo.com
Old 07-23-2009, 08:30 PM
Flowjoe's Avatar
Flowjoe Flowjoe is offline
Email sent
Old 07-23-2009, 08:39 PM
Ollie's Avatar
Ollie Ollie is offline
E mail sent
Its ok to giggle and snicker, Dont laugh and point
Old 07-30-2009, 01:49 PM
ScottD3 ScottD3 is offline
email sent
Old 07-31-2009, 09:35 AM
PM Sent
Old 07-31-2009, 09:36 PM
inthuwind's Avatar
inthuwind inthuwind is offline
You have a good shifter plate? Pics, price shipped to 79602 please.
Dad always said,"Son, if you can't be good...be good at it."
Old 08-01-2009, 10:52 AM
the only one i have right now has mounting hole issues
Old 08-02-2009, 03:08 PM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
looking for hood hinge for my 74 ta (pass side) or both. Must be in good shape?
pm to transamrip@yahoo.com
thanks
1974 400 4 speed
Old 01-22-2010, 01:23 AM
Alamo's Avatar
Alamo Alamo is offline
I need doors for a 78 Firebird with manual locks / manual windows. I have pl/pw that are non-functional. I think it would be simpler just to convert to manual. Could use some door pannels and decent seats too (Camaro interchangeable OK).
I visit the Brazos Valley sometimes - got relatives there. Maybe you could help me out. Send me a PM with contact info or reply.
Thanks,
Garrett
Corpus Christi, TX
Old 01-22-2010, 01:27 AM
Alamo's Avatar
I just saw your contact infor at the end of your post - sent you an email. thanks, Rusty. Look forward to talking with you.
Old 01-22-2010, 03:01 AM
chris everitt's Avatar
chris everitt chris everitt is offline
Default toe board panel
Im looking for a right toe board for a 75 t/a just above the floorpan seam, picture attached. sent email
Name:	ta pics 002.jpg
Old 02-03-2010, 11:07 PM
Pontiac Inc.'s Avatar
Pontiac Inc. Pontiac Inc. is offline
Default parts
do u still have trunk springs (rods) plz, i have a '76
Mrs. cleavor told ward "you were a little hard on the beaver last night"
76 T/A 455 700R4 HO heads, Longtubes
87 buick GN, 252 ci, TE-44,22 psi, meth injected, hyd. roller,ported heads, intake
81 pace car ws6
79 k code T/A
02 F150 supercrew 4X4
69 boss 302
79 W72 4 speed 400 ws6 hard top
Old 02-09-2011, 03:23 PM
ricky80ss ricky80ss is offline
hi, I need a pair of Hurst t toops U frames, the ones bolted to the roof, 1sr design, can you help get me a set?
Old 02-10-2011, 11:03 AM
all I have is a hurst t top bag with a divider in it.
Sorry,
Gotsnappy
Old 05-29-2011, 08:17 PM
Still have lots of parts to get rid of
Old 05-29-2011, 11:05 PM
Ben Ben is offline
How much for the Radiator shroud 2 piece ? shipped to KS 66212
Old 05-31-2011, 09:15 AM
50.00 plus whatever actual shipping is. I would have to calculate it fo you if intereested
Old 05-31-2011, 10:13 AM
abefromen's Avatar
abefromen abefromen is offline
pm sent
Old 05-31-2011, 11:35 AM
Ben Ben is offline
Pm sent
Old 07-02-2011, 09:12 AM
I still have lots of parts, I need to get rid of...............................
