Holley HP950 Issue
My Holley is acting up on my TA street car....it will run fine at idle and below 2000 rpm but when you give it gas and I mean gently.. the carb floods out. Have to floor it and crank it until it clears out and then the car will run again.
Any ideas ?? Thanks Lee
1970 Trans Am Vortech X Trim 397ci Ram Air V |
Sounds like the power valve or the gaskets have dried out and now when the main circuit comes in it gets a lot of fuel from the gasket leaks into the boosters vs coming through the jets.
Tom Vaught
Check for vacuum leaks as well.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
What happens if you give it gas by TROMPING the pedal? (i.e., NOT "gently")
thanks for the help guys....Hey Tom did you get my PM....when I tromp the pedal it will go like a bat out of h%$#@ but under regular acceleration it dies ...
Lee
