mini spool-will it break
My wife's bracket car is getting a trans brake for this season but has a 31 spline mini spool in a 9" Ford rear.
I'll probably put in a full spool later but just not sure if really required as this car is easy on parts. It's 2300 lbs with driver/4.56 gear and a 300 hp SBC. Do you think the mini would live with the T-brake? |
dont do it! it will break. I destroyed a 31 slpine one and ruined the case too, weighed a little more and was running low 11's at the time, and had 455 torque with 411s! but Id recommend against
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
With the SBC I would worry about the Carrier or the pin breaking first. With only 300hp the Minni is good. get over 400hp then you can worry about the Minni.
Why is he not suspended? |
It will break! Don't do it!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
I ran mid 10's with miny, also ran mid 11's in another, and a hi 11 sec street car...all heavy all 455's no prob...stock axles too!
i ran one in my firebird before i went to aftermarket axles. 28 spline steel mini and i went mid 10s, 3500 pounds. i did strip an aluminum one out, then went with the steel one. when i broke an axle i went to 35 spline and a real spool.
I have a spool for a 9 inch in my shop thats brand new. I think its 31 spline. I dont own it but im sure the owner would sell it.
Rex
http://home.adelphia.net/~fbnr/1968firebird.html |
I"ve been looking for a good used one but no luck for 2.892 housing. I think I'd rather risk the mini than cough up for new.
A friend of ours on our racing team had a 79 Monte Carlo that weighed 2770 with driver - had an sbc 350 with 76 cc 400 scb heads - flat top pistons and a 305S-10 Comp Cams Magnum hydraulic cam. car ran low 12's most of the time, went a best of 11.91 running a T-350 with line lock both on the front and rear wheels with an air controlled throttle stop all hooked up to the delay box, car had mid to low 1.60's 60' times with a narrowed 9", 31 spline axles and a mini spool. He broke so many carriers and pins it almost wasn't funny (but it was kinda lol) The 9' mini spool set up is no where near as strong as a GM set up because a 9" carrier gets un-bolted into two halves, replace the spider gears with the mini spool but there is about a 1/2 inch of space from the mini spool to the inside of the carrier which gives the applied torque "leverage" on the cross pin which wants to turn it into sort of a "Z" untill it and the carrier breaks.
The GM set ups are a 4 peice deal where the square chunks that act as the small pinion gears where the cross pin goes through goes right up against the inside of the carrier where there is no gap at all, that way the pin, which is by the way a larger diameter pin than what the 9" pin is, would have to be "sheared" off as the torque has no "leverage" to try to bend the pin till it breakes type of deal. I ran a mini spool in my Wagon untill 2002 going 1.401 in the 60' with a T-brake at 3300 lbs. then it went into my Dads 79 Grand Prix going low to mid 1.40's 60' since then... They're pretty tough but the 9" ones are a NO NO!!! Go to Ebay and look up a seller named Staticz2229 he has a lot of 9" stuff and it's mostly Strange stuff, I got my whole Strange center section kit from him, case, spool and installation/bearing kit for less that half of what Summit or Jegs would have been. Here is a link to a spool he has, it may not be what you need but click on his other items and I'm sure you'll find what you need or call him, he'll get it! http://cgi.ebay.com/ebaymotors/ws/eB...3731&viewitem= Thanks D. Miles
Going TurboCharged! Last edited by D. Miles; 03-16-2009 at 12:19 AM. |
He proubly would sell it resonable. maybe 75 bucks? its new.
Rex
Thanks, Keith |
keith definately take the safe route here
With stock axles why do more? I might have used a welder instead.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson "If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams Right and wrong doesn't need facts all the time. -Lighthouseman ("lawyer") Starnes Performance Automatics www.Starnesperformance.com |
This car is using shortened stock axles but the 31 spline units from this Ford are the same diameter as my 33 spline Moser axles in the T/A and huge compared to the factory axles that were in my 10 bolt. The steel may not be as good but they sure are beefy.
I checked the link from D. Miles and think I've got a deal from him. Thanks |
