Old 02-11-2009, 12:28 AM
65lemans's Avatar
65lemans 65lemans is offline
Question Vacume Advance Can P/N
Hey Guy's , Does anybody have the P/N to the Vacume Advance Can that only puts out 10 degrees advance ? Thanks...
65lemans
Old 02-11-2009, 02:11 AM
Try an Echelin # VC1809 can.
Old 02-11-2009, 06:22 AM
Kenth's Avatar
Kenth Kenth is offline
Even the VC1809 may have the range shorten some for 10 degrees at crank?
VC1809 (stamped B27), starts at 5-7 in/hg, max advance 9 degrees at distributor (18 at crank) @ 10-12 in/hg.
Old 02-11-2009, 07:55 AM
65lemans's Avatar
Thanks Guy's....
Old 02-11-2009, 10:37 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The NAPA vacuum advance units are quickly becoming extinct. I suspect the same from other sources.
A few months ago we went thru our list of part numbers, and all but 3 vacuum units had been discontinued.
You may end up getting a B-1 can and reducing the travel to obtain exactly 10 degrees at the crank. I can't provide the exact part numbers from NAPA, etc as we lost that information when our hard drive crashed.......Cliff
Old 02-11-2009, 12:22 PM
I was using dist degrees, not crank when he said 10º.
Sounds like the Crane kit would fit the best.
Old 02-11-2009, 12:56 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I found this awhile back and found it quite useful. I went with the B1 (Part# VC680 NAPA) myself and limited the advance. Specs and part numbers in the back. All the part numbers I looked at were available from NAPA in the Denver area.
http://www.corvette-restoration.com/...c_Adv_Spec.pdf
Damn sure can't argue with Greg though...
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
