Help me ID this Poncho flywheel......
Hello guys...
Here's an old flywheel I have and I would like to know from what engine/body it could have come from. It's much thicker then a 389 flywheel I have from a GTO and other Pontiac flywheels that I have... See pictures! Looks like it uses a 10.5" diameter clutch disc... Thanks! KR
*** THE BIG BRACE is here *** |
flywheel
looks like an early 60's big car flywheel. I have or (had) one hotchief
Measure the inside crank diameter and the maximum outside. Also weigh it.
the big diff from early and late 61 and up is the location of the ring gear.Will look when I get a chance.One is closer to the block and the other is farther.Has to do with a bell mounted starter and a block mounted one.Tom
