Old 11-01-2008, 06:06 PM
spb350 spb350 is offline
Default Which trans cooling line goes where?????????
I bought new trans cooling lines and I'm not sure which line goes where. Bought the stupid service manualand it doesn't have crap for info. Does the short line go on the top or bottom. Thanks for a quick response.
73 Trans Am Red/White #'s match 4spd...... sold
69 Firebird 400 conv #'s match AT Blue wht/wht
06 Vette conv Red/Red/Blk
Old 11-01-2008, 06:56 PM
stevep's Avatar
stevep stevep is offline
It really does not make much of a difference.
I would say that top line on the trans goes to the top line on the radiator.
Old 11-01-2008, 07:50 PM
Also do the lines go over the top or under the motor mount, thanks
Old 11-01-2008, 07:52 PM
On the 67 radiator the trans lines are both located on the bottom of the radiator, not like the later models where they are stacked
Old 11-01-2008, 08:18 PM
wytnyt's Avatar
wytnyt wytnyt is offline
under the mounts and above the crossmember
Old 11-01-2008, 10:00 PM
Does it matter which line goes where? or is it just a loop?
Old 11-01-2008, 10:45 PM
Here's a shot of the empty engine compartment on my '64 Tempest. I was using a set of repro '67 GTO trans lines in it, was running a 455 with TH400 trans along with a repro '67 radiator. The '67 trans lines fit perfectly in the '64 -'67 Pontiac A-body cars.
The lines are held in a rubber-insulated clip bolted to the frame next to the passenger side motor mount bracket. Hopefully this photo will help you figure out what you need to do.
Old 11-02-2008, 10:28 AM
Thanks bman helps a bunch
Old 11-02-2008, 01:36 PM
engineer engineer is offline
lines go over the mounts, not below as pic'ed.
Old 11-02-2008, 06:01 PM
fyrffytr1's Avatar
B-Man, I see you are adding a lead substitute to your gas.
Old 11-02-2008, 06:26 PM
I knew someone would notice my trick adaptation of that fine writing instrument.
The pencil was a perfect fit.
