Old 10-26-2008, 11:09 PM
69camarox 69camarox is offline
Default firewall hole??
hi can anyone tell me what this hole in the firewall is for ??
thanks Bruce
ID:	146641   Click image for larger version
Old 10-26-2008, 11:36 PM
LPete LPete is offline
I think that's where the vacuum harness for the hidden headlights goes through.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
Old 10-27-2008, 07:40 AM
Forrest's Avatar
Forrest Forrest is offline
Also on 70 and earlier there is a orange "pigtail" power supply that runs from the fuse block thru the hole to the horn relay
Old 10-27-2008, 12:23 PM
gto4evr gto4evr is offline
Also where the cruise speedo cable goes through. basically an accessory access hole. Not all the bodies had them, when I added cruise to my 71, there's no hole in the metal there. My 69 convertible had the hole with a rubber grommet plugging it up since the car didn't have any of those options on it.
Old 10-27-2008, 09:10 PM
ok. was wondering if that was the hole that my hood tach light wire went through the firewall??
wiring to horn relay makes sense
does not have hidaways or cruise
Old 11-02-2008, 07:21 PM
motorcitymusclecar motorcitymusclecar is offline
That hole in the firewall was used to run accessories as stated above. If you had Hide-a-ways it got the 3 hole plug - that is used for the vacuum hoses and if you had a hood tach it got a single hole plug for the tach wire. If the car had none of these options there was no hole. So if adding option you will have to drill it - I believe it is 1" and there is a locating dimple on the firewall to find the center. here is a picure of the three hole grommet. So yes your hood tach wire goes through that hole but not the horn relay that is part of the engine harness.
