I've got to check my fuel sending unit - is there a way to pull it and replace it WITHOUT dropping the gas tank?
Thanks...
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
depends which car, like on a 67 or earlier A body, for sure, no problem.
![]() Quote:
My 66 LeMans - do I have to drop the fuel tank to check/replace the fuel sending unit?
You do not have to drop the tank, I would however make sure it is relatively low on gas, there will be less spillage. I would also recommend a new rubber seal, will be easier to get back on.
67 GTO Hardtop |
![]() Quote:
Sorry, newby here! ![]()
It can be done with some patients.
![]() ![]() Get a new lock ring and rubber gasket as was mentioned and VERY little gas in the tank. |
also when tapping on it,,rotate from one tang to the others as the lock ring is a tad smaller and may get pushed to one side
rotating on the tabs will help yo keep it centered |
Yup!
Got the sending unit out, had to drop the tank - wanted to anyway, to clean it out. Don't need to, it's nice and clean inside! Who would've thought, after 42 years?!
Picking up a new "sock" for the sending unit and new rubber gasket and O-ring - still need to get the carb back to the guys that sold it to me. It's getting there!
I've done the ''hammer and screwdriver'' thing a few times too.Just a word on safety.Use a brass screwdriver substitute.Its way too easy to cause a spark when the screwdriver slips off the tab.
Also, put grease on the rubber O Ring, it will help it to slide while tapping it in.
![]() Quote:
FYI Anyone out here on the West Coast - Classic Industries sells the Sending Unit Filter Screen, OPG doesn't - but it's the same part. Classic Industries Part# K404 Cheers!
It does tend to squirm and can get cut or pinched.
Got the gas tank/sending unit back in, fired it up - no leaks and the car is running fine. Need to replace the stat on Monday and HOPEFULLY that takes care of the overheating problem...
Thanks guys for all your help!
