et improvment by changing heads only!!
hi guys! i thought it would be interesting what you other guys gained by changing heads only!-all other things remained the same !! carb & intake manifold change is allowed when also tested on the original combo!!
I have a bunch of info on a head change from a 308cfm E-head (88cc) to a set of out of the box (90cc), 360cfm at my .650 cam lift!!! CV-1's in my 76 T/A. Pump gas, hydraulic roller. It's located here. http://www.pontiaczone.com/forum/showthread.php?t=22196
You can sort thru all the negative crap and hassle then form your own opinions. I'm happy and not looking back. Only change was the heads and worth .3/.4 depending on the weather conditions taken into account. Last edited by PONTIAC DUDE; 08-08-2008 at 12:25 PM. |
Do not forget, a head change also may dictate a compression change.
I picked up 75 RWHP with no changes except from 230ish ported 6x heads to 310 KRE D ports.
68 Firebird Are you running with the wind or breaking it? |
.5 second
#62 's to Edelbrock's = five tenths
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Went from a set of mildly ported 6-8Xs to out of the box KREs [260] cfm and picked up about one half second.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
I picked up 1 second and 10 mph going from a set of stock 51 heads to a set of ported 6x's. With no other changes.
Changed from 265 cfm #62 D-ports and a Warrior to High Ports and a Victor. Same carb, same cam, same exhaust system, but with round port headers. Compression went from 10.2:1 to 11.3:1 with the chamber size difference. Still on pump gas though.
Previous best - 11.45 @ 116 New best - 10.59 @ 124.5
Brian Rock '65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs. 9.88 @ 134 N/A on Cali 91 octane. http://www.youtube.com/watch?v=NJEIY5OJ68g |
I went from 12.10's to 11.50's changing from kre poted 248cfm #96's to 310 cfm kre d ports. solid flatt tappet cam at 3995lbs. this is a street car driven 140 miles to the track.
Changed from ported ram air 4's to ported E-heads. Went from a best of 6.58 in the 1/8th to a best so far of 6.10.
