Old 08-02-2008, 09:17 AM
dancolkate's Avatar
dancolkate dancolkate is offline
Default 68 GTO frame VIN and rear end ID
I pulled the body off one of my parts cars. I don't remember where to look for the frame VIN to see if it was the original frame, and also I can't find a two letter code stamped in the axle tube. Any help is appreciated.
Old 08-02-2008, 09:55 AM
JLHarper's Avatar
JLHarper JLHarper is offline
Here is a good post with pictures:
http://forums.maxperformanceinc.com/...e+vin+location
They can be very small, stamped lightly, and hard to spot.
Old 08-02-2008, 12:16 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
This will make it easier
http://forums.maxperformanceinc.com/...3&postcount=15
For your differential numbers, look on the rear facing side of the axle. My marks are stamped on the passenger side tube
Old 08-02-2008, 12:30 PM
68gtoMN,
That's interesting. How do you go about linking a single post?
Old 08-02-2008, 01:57 PM
dancolkate's Avatar
It looks like code SE is stamped in the passenger side axle tube. Doesn't look like a Pontiac rear. But what is it?
Old 08-02-2008, 01:58 PM
dancolkate's Avatar
68gtoMN,
Click on the post number in the upper right corner of any post. Then copy/past the url. Wahla
Old 08-02-2008, 08:58 PM
Thanks...never knew that.
By the way...It's definitely not a Pontiac rear end. I think it's an Olds rear.
Here's a site that will help you though...
http://oldsmobility.com/reardiffs.htm
Check out the related links near the bottom of the page too.
Old 08-05-2008, 10:44 AM
dancolkate's Avatar
Thanks everyone for the info.
If there was a VIN on this frame, it's gone now due to some heavy rust. Without any visible numbers, is there any way to identify a GTO frame from a Cutlass or Chevelle frame?
